X10 PRO 1-Button Keypad (All On/All Off), White
$11.95
  • Centralized Lighting Control: Manage all your X10-connected lights simultaneously with one simple button press
  • Seamless Integration: Works with the X10 PRO Controller and XPT Wall Transmitter Base Module (sold separately) for easy setup
  • Sleek and Modern Design: The white finish blends effortlessly into any home décor
  • No Extra Wiring Needed: Uses your home’s existing electrical wiring for communication, reducing installation hassle
  • Reliable Performance: A trusted Smart Lighting Switch solution with long-lasting functionality
The X10 PRO 1-Button Keypad (All On/All Off) is an essential addition to your home automation setup, providing seamless and centralized control over your lighting system. Designed to work with the X10 PRO Controller, this keypad ensures effortless operation, allowing you to turn all connected lights on or off with a single press. Whether you're enhancing security, improving convenience, or optimizing energy efficiency, this Smart Lighting Switch is a must-have for any X10-enabled home.
  • Centralized Lighting Control: Manage all your X10-connected lights simultaneously with one simple button press.
  • Seamless Integration: Works with the X10 PRO Controller and XPT Wall Transmitter Base Module (sold separately) for easy setup.
  • Sleek and Modern Design: The white finish blends effortlessly into any home décor.
  • No Extra Wiring Needed: Uses your home’s existing electrical wiring for communication, reducing installation hassle.
  • Reliable Performance: A trusted Smart Lighting Switch solution with long-lasting functionality.
Usage & Benefits
The X10 PRO 1-Button Keypad is perfect for users who want instant control over their home's lighting. Simply attach it to the XPT Wall Transmitter Base Module, and pressing the button will send a command through your existing wiring to turn all X10-enabled lights on or off. This feature is ideal for whole-house lighting control, improving energy efficiency and convenience.
  • Enhanced Convenience: Instantly switch all lights on when you enter or off when leaving home.
  • Energy Savings: Ensure no unnecessary lights are left on, reducing electricity costs.
  • Security Boost: A quick way to illuminate your entire home at night for safety.
By integrating the X10 PRO 1-Button Keypad into your system, you get a Smart Lighting Switch that simplifies your home automation experience while offering reliable performance and convenience.
