X10 PRO Heavy-Duty Wall Switch, 20A, 240VAC
$51.95
The X10 PRO Heavy-Duty Wall Switch is the perfect solution for anyone looking for a reliable and durable switch for their home or business. With a maximum capacity of 20A and 240VAC, this switch is capable of handling even the heaviest loads with ease.
Constructed from high-quality materials, this switch is built to last and can withstand even the toughest conditions. Its heavy-duty design ensures that it can handle constant use without any issues, making it perfect for high-traffic areas like commercial buildings, warehouses, and factories.
Installation is easy and straightforward, and the switch is fully compatible with X10 automation systems, allowing you to control your lights and appliances with ease. Whether you're looking for a reliable switch for your home or business, the X10 PRO Heavy-Duty Wall Switch is the perfect choice.
