X10 Push Button Dimmable Wall Switch Module
$29.99
  • Versatile Compatibility: Supports dimmable LED, halogen, and incandescent bulbs up to 500W, ensuring broad applicability across different lighting setups
  • Integrated LED Indicator: A built-in LED softly glows in the dark, making it easy to locate the switch during nighttime
  • Remote and Local Control: Utilizes X10 Wall Switches technology to respond to X10 On/Off/Dim/Brighten commands, offering flexible lighting control options
  • Neutral Wire Requirement: Requires a neutral wire for installation, ensuring compatibility with modern electrical systems
The X10 Push Button Dimmable Wall Switch Module (WS18A) enhances your home lighting by providing seamless control over various light sources. Designed to replace standard wall switches, this module integrates X10 wall switch module technology, allowing both local and remote management of your lighting fixtures.
  • Versatile Compatibility: Supports dimmable LED, halogen, and incandescent bulbs up to 500W, ensuring broad applicability across different lighting setups.
  • Integrated LED Indicator: A built-in LED softly glows in the dark, making it easy to locate the switch during nighttime.
  • Remote and Local Control: Utilizes X10 Wall Switches technology to respond to X10 On/Off/Dim/Brighten commands, offering flexible lighting control options.
  • Neutral Wire Requirement: Requires a neutral wire for installation, ensuring compatibility with modern electrical systems.
The Wall Dimmer Switch is ideal for creating the perfect ambiance in any room. Whether you're dimming the lights for a cozy evening or brightening a space for reading, this switch provides precise control. Its compatibility with various bulb types and the convenience of remote operation make it a valuable addition to any smart home setup.
Installation Note
This switch is suitable for single-pole applications; for 3 or 4-way circuits, it is compatible with the X10 Companion Wall Switch (CS277). Please note that lamps rated below 6W may flicker or operate erratically with this switch and should not be used. A neutral wire is required for proper installation.
