X10 Push Button Relay Wall Switch
Regular price $35.95
Regular price $35.95 Sale price
Shop X10 Push Button Relay Wall Switch With Perfect for LED & Incandescent Lights
The X10 Push Button Relay Wall Switch is a versatile and reliable solution for modern home automation, designed to seamlessly integrate with various lighting systems. This Relay Wall Switch is compatible with a wide range of lighting types, including incandescent, LED, halogen, and fluorescent bulbs, ensuring consistent performance across different fixtures.
  • Universal Compatibility: The X10 Wall Switch supports multiple lighting types, making it a flexible choice for diverse home lighting setups.
  • LED Indicator: Equipped with a built-in LED, the switch provides a clear on/off status and assists in locating the switch in low-light conditions.
  • Easy Installation: Designed to fit standard toggle-style wall plates, the switch requires a neutral wire for installation. Simply replace your existing switch, set the desired house code, and it's ready to operate with your preferred X10 controller.
  • Enhanced Construction: Built with improved materials and design, the switch offers a superior tactile feel and increased durability compared to previous models.
The X10 Push Button Relay Wall Switch is ideal for homeowners seeking to upgrade their lighting control without extensive rewiring. Its compatibility with various bulb types, especially LEDs, addresses common issues such as flickering or incomplete shutdown experienced with older switches. Users have praised its performance, noting that it works flawlessly both manually and with wireless remote receivers through the X10 network. The inclusion of a neutral wire connection ensures stable operation, and the LED nightlight feature adds convenience by helping locate the switch in the dark.
Specifications
  • Model Number: WS469
  • Power Supply: 120 Volts AC, 60Hz
  • Maximum Load: 10 Amps / 1000 Watts
  • Wiring Requirements: Neutral wire required
Upgrade your home lighting control with the X10 Push Button Relay Wall Switch, and experience seamless integration, enhanced functionality, and the convenience of modern home automation
