Shop X10 Slimline Wireless Wall Switch 3-Address Dimmer for Smart Home Control
The X10 Slimline Wireless Switch is the perfect solution for effortless and flexible lighting control. With its ultra-thin design and wireless functionality, this switch allows you to manage your home’s lights and appliances without any complex wiring. Whether you need a convenient switch by your bedside, near an entrance, or in hard-to-reach areas, this device offers seamless control over up to three X10-compatible modules.
Wireless & Slim Design: The X10 Wireless Wall Switch blends into any environment with its ultra-thin profile (just 7mm thick). Mount it anywhere without drilling or rewiring.
3-Address Control: Easily operate up to three X10 receiver modules from a single switch using the X10 3-Address Dimmer Switch.
Dimmable Lighting Control: Adjust the brightness of compatible X10 dimmable devices to create the perfect ambiance.
Easy Installation: No need for in-wall wiring! Simply attach it to any surface using the included adhesive or screws.
Compatible with X10 Home Automation: Works seamlessly with X10 transceiver modules (sold separately) to extend your smart home setup.
Usage & Benefits
The X10 Slimline Wireless Switch is ideal for adding secondary lighting control points without extensive electrical work. Install it near doorways, beds, or workspaces to conveniently manage lighting or appliances. The X10 3-Address Dimmer Switch ensures you can operate multiple lights or devices from one location, enhancing comfort and energy efficiency.
With the X10 Wireless Wall Switch, you can enjoy complete control of your lighting and appliances while maintaining a clean and modern look in your home.
