Have an account?
Loading...
Xiaomi Water Sensor Flood Leak Detector App Remote Monitoring for Kitchen/Bathroom Support Home Assistant Zigbee 2mqtt
1.Power Input: DC3V CR2032 battery2.Working Temperature: -10°C- 55°C3.Communication Protocol: Zigbee 3.04.Battery Working Life: more than one year, 20 times a day (replaceable)5.Material: ABS6.System Support: l0S8.0/Android4.0 and above7.App Name: Smart Life/TUYA8.Product Size:5*5*1.5CM
Features:
1. Zigbee Communication Method :The Tuya Zigbee Water Leak Detector uses Zigbee communication method, ensuring a stable and reliable connection.2.Smart Life App Alert :Receive alerts on your smartphone via the Smart Life app when the water leak detector detects any leaks or floods.3.Overflow Water Leakage Sensor :The overflow water leakage sensor ensures that you are alerted even before any damage occurs4.Kitchen/Bathroom Use :The Tuya Zigbee Water Leak Detector is perfect for use in kitchens and bathrooms, where water leakage is a common problem.
Package Included:
1 *Water sensor1*Manual
Start Building Your Ezlo Home
Xiaomi Water Sensor Flood Leak Detector App Remote Monitoring for Kitchen/Bathroom Support Home Assistant Zigbee 2Mqtt
