Zen Wi-Fi Thermostat
Regular price $199
Regular price $199 Sale price
Shop Zen Wi-Fi Thermostat
The Zen Wi-Fi Thermostat is the perfect addition to any modern home. With its sleek design and easy-to-use interface, this thermostat allows you to control the temperature in your home with ease. The Zen Wi-Fi Thermostat is compatible with most HVAC systems and allows you to adjust the temperature from anywhere using your smartphone or tablet.
With its built-in Wi-Fi connectivity, you can easily monitor and control your home's temperature remotely, making it the perfect choice for busy families on the go. The Zen Wi-Fi Thermostat also features a customizable display that allows you to choose from a variety of colors and styles, so you can match it to your home's decor. Whether you're looking to save money on your energy bills or simply want to stay comfortable all year round, the Zen Wi-Fi Thermostat is the perfect choice.
Key Features:
  • Sleek Design: Modern and stylish to fit any home decor.
  • Remote Control: Adjust the temperature from anywhere using your smartphone or tablet.
  • Compatibility: Works with most HVAC systems.
  • Customizable Display: Choose from a variety of colors and styles to match your home.
  • Energy Efficiency: Helps you save money on your energy bills by optimizing temperature settings.
Upgrade your home’s climate control with the thermostat Zen and experience the perfect blend of style, convenience, and efficiency. The Zen Thermostat Wi-Fi is designed to make your life easier and your home more comfortable.
Manufacturer Part # ZEN-02W
System Control Temperature Control Modes: Cool, Heat, Auto, and Emergency Heat
Fan Modes: 1, 2, or 3 stage fan systems, with auto fan mode
Environment Sensing: Temperature
Temperature Adjustment: ± 1 °F OR 0.5°C
Design User input: Touch interface
Display: LED Matrix
Wall mounting: Mounting bracket with magnetic connection to main body
Color: White body with White display, Black body with White display
Dimensions:
Thermostat: 4.33 (H) x 4.33 (W) x 0.88 (D) inches
Wall Plate: 5.91 (H) x 4.73 (W) x 0.20 (D) inches
HVAC System Compatibility Heating System Types: Forced Air, Heat pump, Gas, Electric, Millivolt, Hydronic
Heating stages: 1 or 2, plus emergency heat
Cooling Systems: Heat pump, Evaporative, Hydronic
Cooling stages: 1 or 2
Heat Pump support: Two-stage reversible heat pump (with Auxiliary/Emergency Heat)
Connectivity Wireless protocols: 802.11 B/G/N 2.4GHZ
Firmware upgrade: Over-the-air (OTA) upgrade
Compatibility: iOS (iPhone, iPad, or iPod Touch 9.0 or later) Android (6.0 or Later) OpenHome approved, SmartThings, SwannOne, Almond+, Securifi
Setup and Installation HVAC system rating: 24V AC (nominal); 2A max per relay
Battery Life: 2 years (on 4 x AA batteries, with typical use) Continuous operation if a C-wire is connected
Installation Manuals: Paper-based quick-start guide; Web-based system setup and wiring guide
Display Language: English, French, Spanish
Regular price $199
