ZEXEF TUYA Smart Liquid Leak Sensor Zigbee 3.0 Water Sensor Detector Remote Monitoring Support Home Assistant Zigbee2Mqtt
Smart Zigbee Water Leak Detector – Instant Flood Alarm with 110dB Siren & IP67 Protection
Core Specifications:
Parameter Specification
Detection Sensitivity 0.4mm Water Depth
Wireless Protocol Zigbee 3.0 (Hub Required)
Alarm Volume 110dB Audible Alert
Power Supply CR2032 Battery (1-Year Lifespan)
Dimensions 80×40×15mm (3.15×1.57×0.59")
Protection Rating IP67 Waterproof & Dustproof
Key Features:
✅ Instant Dual Alerts:
Ear-piercing 110dB siren + app notifications (iOS/Android)
Triggers smart valves* to shut off water supply (*valve sold separately)
✅ Precision Detection:
Dual probes detect leaks as low as 0.4mm (0.015 inches)
Self-test function for sensor reliability
✅ Low-Maintenance Design:
1-year battery life with low-power alerts
Wall-mount or freestanding placement
Technical Certifications:
CE/FCC/RoHS Certified
Zigbee 3.0 Global Standard
Applications:
🏠 Home: Under sinks, near washing machines, water heaters
🏢 Commercial: Server rooms, hotel basements, retail stores
🏭 Industrial: Pipe junctions, HVAC systems, production floors
Installation Guide:
Place sensor horizontally in flood-prone areas
Pair with Zigbee hub via 5-second button press
Test using water droplets (included manual)
Package Includes:
1× Water Leak Sensor
1× CR2032 Battery
2× Mounting Accessories (adhesive pad + screws)
Performance Data:
Metric Value
Response Time ≤2s
Wireless Range 50m (open area)
Operating Temp -20°C to +60°C
Advanced Functions:
Multi-Sensor Sync: Monitor 15+ detectors in one network
Historical Logs: Stores 30+ leak events with timestamps
Test Mode: Simulate leaks for routine checks
Note: Requires Zigbee hub (sold separately). Avoid placement near steam sources. Replace battery when low-power indicator flashes.
The following are all the sales specifications of this product:
Water immersion sensor WL08
Water immersion sensor WS03
Tuya Zigbee Gateway
