Zigbee 24G Radar Human Presence Sensor Static Motion Occupancy Sensor Brightness Temp Humidity Detector Z2M Tuya Home Assistant
*Compatible zigbee hub is required ,.they cannot work alone without related gateway.
【What is the difference between Z2M and Tuya Zigbee version?】
*Zigbee 3.0(Z2M): Need work with zigbee2mqtt on home assistant via related gateway.Not support for tuya nor smart life gateway.
*Tuya Zigbee:Need work with tuya zigbee gateway,Also compatible with zigbee2mqtt on home assistant via related gateway.Not support for ZHA(zigbee home automation )
1.Zigbee 3.0(Z2M):24G Radar Presence sensor+Lux+Temperature and humidity sensor ,only work on zigbee2mqtt;
2.Tuya Zigbee:24G Radar Presence sensor+Lux+Temperature and humidity sensor ;Not only support For tuya zigbee gateway via tuya smart life app,but also support for zigbee2mqtt;
Product name :Zigbee Occupancy Sensor
Battery: CR2450 Button Battery(Included)
Wireless: Zigbee 3.0
Radar: 24GHz
Working Voltage: DC 3.0V
Standby current: <60uA
Detection angle:≥ 80°
Detection distance :≤ 5m
Temperature Humidity Lumiannce Function: It is additional version.(24G Presence with LUX TH)
24G Presence Sensor Function Description
Zigbee Occupancy Sensor means zigbee human presence sensor,it can detect motion and static status.
• Click "SET" " to turn on/off the LED indicator light, which will stay on once to indicate it is turned on, Flashing 3 times, closing the meter
• The default duration for someone to hold it is 30 seconds, which can be set on the app
• The 24GHz radar version supports static detection and motion detection
• There is a detection version available at 24GHz, with motion/static sensitivity- The higher the value, the more sensitive it is If the default parameters trigger false alarms, please reduce the motion detection sen sitivity. If the static state cannot be maintained, you can increase the static detection sensitivity and Set. the 'Presence Keep Time' time to a Longer value.
•Create smart scene and linkage with other zigbee devices
