Zigbee 3.0 Motion Sensor with Pir IR Infrared Human Body Mini Security Detector Home Battery Devices Tuya Smart Life Smartlife
Wenzhi ZigBee Human Motion Sensor
Human motion sensors detect the movement of people or animals in the environment by infrared, and combine with other intelligent devices to realize intelligent application scenarios.
This Zigbee senosr and detector can not work standalone without ZigBee gateway.
Networking form: ZigBee3.0 Mesh
Detection:120°,distance < 5M
Power input:CR2032 button battery(1 years,10 times per day)
working temperature:-10°C~45*C
Product size:55mm*28mm(body) 38mm*22mm(base)
Appearance packaging:White carton neutral packaging
【History Records Tracking】You can track the history of sensor activities.
Package:
ZigBee Motion Sensor*1
Stickers*1
Advanced Motion Sensor
PIR detects human body or animals that are moving, 120° detection angle, 5m detection distance, can achieve real-time monitoring day or night.
Emergency Alert Push Function
When there is movement detected, the alert notifications will be pushed to your phone, be aware of what's happening at home even when you're away.
Multi-Scenario Application
The lamp can be turned on automatically when people approach.Easy installation in various occasions
Effectively Shock Thieves
When away from home, the mobile phone receives the alarm notification triggered by the human sensor.
New shell update
1. A new power switch is added to turn off the power when not in use, which saves battery power. It can significantly reduce battery loss during transportation.
2. 360° rotatable angle.
3. The base has screw holes. You can stick it on the wall or fix it with screws. There will be adhesive strips in the package.
Installation
Note:Add ZigBee intelligent gateway before adding this device.And install the battery on the device and make sure the mobile phone is connected to the network.
STEP1
The first power on will automatically enter the distribution network mode, or press the reset button (the reset button is on the right of the product) with the pin for more than 5 seconds, and the device indicator will flash to enter the distribution network mode. After the distribution network is successful, the distribution network indicator will go out.
STEP2
Open the app, click the gateway, and add a sub device under the gateway. Make sure that the system automatically searches for the device after the indicator light flashes. After waiting for one minute, the system can automatically add the device.
This Zigbee senosr and detector can not work standalone without gateway.
