Zigbee Motion Sensor Human Body Sensor Movement Infrared Wireless Connection Smart Home Work with Tuya Smart Life Need Hub
Smart ZigBee PIR Motion Sensor Water Leak Sensor Door Window Sensor SOS Emergency Button Siren Alarm Intelligent Linkage
By Meian
Notes:
ZigBee hub is a required.
ZigBee devices needs to use ZigBee gateway to connect to APP and push information.
The gateway needs to be purchased separately.
The Meian gateway has been upgraded to the latest version, which can better work with Meian devices. Other versions of gateways are not guaranteed to work with all Meian devices. It is recommended to purchase a Meian gateway. Thank you!
Product Features:
PIR Motion Sensor:
90° detection angle, 12m detection distance. When the PIR sensor senses a person moving, it will push a warning message to your phone.
Water Leak Sensor:
High sensitivity, when water immersion is detected, the detector will send an alarm signal to the user's mobile phone.
Door Window Sensor:
Easy to install, when the door/ window opens or closes, it will push notification message to you.
SOS Emergency Button:
One click alarm, when encountering an emergency situation, gently press the emergency button and the mobile app will receive an alarm.
Wireless Siren Alarm:
≥100dB loud alarm, linkage with other sensors to achieve intelligent alarm.
Zigbee Gateway Hub:
Supports 2.4G Wi-Fi+ Bluetooth+ Zigbee, it is an essential device for all ZigBee sub devices.
Connection Method: Zigbee
Zigbee Module: V1.0.6
Wireless Type: 2.4GHz Wi-Fi
App name: Smart Life/ Tuya
Working environment: -10 ℃~50 ℃,<95% RH
PIR Motion Sensor:
Water Leak Sensor:
Door Window Sensor 1:
Zigbee Gateway Hub:
