Zigbee Tempearture&Humidity Sensor with Probe Temp Optional 7 in 1 Water Quality Monitor TDS EC SG Salinity Meter Compatible Z2M
$10.79
Color: 3 In 1
Platform Compatibility: It currently supports and only works with Zigbee2MQTT through Home Assistant. A compatible Zigbee gateway is required for normal operation.
NOT compatible with Smart Life, Tuya App, eWeLink App, or not work with Zigbee Home Automation (ZHA) at this time.
3-In-1:
Model:ZG-105NTH
Item: Zigbee Temperature and Humidity Sensor with temperature probe
Detection Range:Air Temperature,Air Humidty,Probe Temperature
Wireless: Zigbee 3.0(need zigbee gateway)
Battery:LR03(AAA) x2 (Not included battery)
Probe Cable Length: 1M
Probe Material:304 stainless steel
Probe Measure Range:-40℃~120℃
Operating Air Temperature:-10°C~60°C
Operating Humidity :0%RH~99%RH
Temperature Resolution :0.1 °C
Humidity Resolution: 0.1%
Probe length: 1 meter
6-In-1:
Model:ZG-101TDS
Feature:Hydroponic and Freshwater High Precision Edition
Detection Range:TDS, Salinity, EC, Water(liquid) Probe Temperpature, Air Temperature,and Air Humidity
Product Name:Multi-Parameter Water Quality Monitor
Wireless Protocol: Zigbee
Working Voltage: DC3V
Battery Type:LR03-1.5V/AAA*2 (Not included battery)
Standby Current:≤20uA
Probe Measure Range:0℃~60℃
Operating Temperature: 10℃~60℃
Operating Humidity:0%~99%RH
EC:0~2000μS/cm,±1%FS
TDS:0~999ppm±1%FS
Salinty:0.0~2.0%,±1%FS
7-In-1:
Model:ZG-109TDS
Feature:Dual mode version of seawater and freshwater
Detection Range:TDS, EC (Electrical Conductivity), Salinity, SG (Specific Gravity), Water(liquid) Probe Temperature, Air Temperature, and Air Humidity.
-Dual Mode Optional : Easily switch between Freshwater Mode (Aquariums, Hydroponics, Drinking water) and Seawater Mode (Marine tanks). (Note: Mode must be selected manually).
MonitorWireless Protocol: Zigbee
Operating Temperature:10℃~60℃
EC:0~20000 μs/cm,±2%FS
TDS:0~13000 ppm ±2%FS
Salinty:0.0~50.0%,±2%FS
SG:1.000~1.050,±0.001
--Remote Monitoring & Historical Data TrackingWireless Remotely Monitoring. The system supports data recording and remote tracking, allowing you to review historical trends, set threshold warnings for abnormal levels, and receive smart alerts directly through your home assistant zigbee2mqtt dashboard.
--Ultra-Low Power ConsumptionLong-lasting battery life: Adopting Zigbee 3.0 low-power technology, data is reported every 10 minutes by default, saving power and making it more worry free.
--Widely Application ScenariosTailored for small closed-loop water circulation systems, this sensor is widely applicable to household freshwater aquariums, saltwater marine fish tanks, indoor hydroponic planting systems and other scenarios. It provides precise and stable water quality monitoring for family aquatic breeding and soilless cultivation.
Important note: Not applicable to swimming pools, large outdoor ponds, industrial wastewater treatment systems and other large-scale water environments.
--Battery Not Included
The sensor is powered by 2pcs LR03 1.5V batteries. Batteries are not contained in the package and need to be prepared by users independently.
--Smart Water Quality Management for a Healthier Aquatic Ecosystem
Monitor, track and optimize your water environment with precise smart sensing technology. Choose the right version for your smart home system and enjoy effortless, professional water quality control all year round!
--Must read before purchasing (please make sure to confirm before placing an order)
System compatibility (extremely important): Currently, this product only supports connection through Home Assistant (Zigbee 2MQTT/Z2M). Tuya, Smart Life, eWeLink, and ZHA systems are currently not supported.
Gateway requirements: This device cannot be directly connected to the internet and must be used with a compatible Zigbee 2MQTT gateway/coordinator (to be prepared or purchased separately).
