Zigbee Temperature Humidity Moisture Detector Smart Soil Tester Moisture Sensor Phone App Realtime Monitor for Home Garden
$35.89
Color: Zigbee 3.0
Feature:
App remote control:remote real-time monitoring of soil temperature and humidity anytime, anywhere via smartphone
Water shortage warning:when the soil reaches a satus of water shortage,the mobile app sends out a water shortage alert you that it's time to water
Real-time detection of status changes:air temperature/humidity value/soil moisture
Wide range measurement:the plant sensor humidity range can reach 0~100%, which can help to quickly identify the soil moisture content and accurately judge whether your plants need watering
Easy to use :the soil moisture meter is light in size and can be carried around, plug and play, has low energy consumption, and can last for a long time. It is a good helper for your garden
Porduct Parameters:
Product name:soil moisture sensor
Wireless protocol:zigbee 3.0
Soil moisture range:0%-100%
Temperature resolution:0.1℃
Humidity resolution:1%
Temperature measurement accuracy:±0.5
Humidity measurement accuracy:±5
Battery type:LR03AAA Battery *2pcs (not included)
Working voltage:DC3.0v
Standby current:≤20uA
Standby time:≥12 month
Temperature unit convery:℃-℉
Working temperature:-10℃-55
Working humidity:max 99RH
Package Listing:
Soil moisture tester*1(no battery)
Manual*1
