1CH Zigbee Tuya Smart Relay Module Home Automation 7-32V Rf433Mhz Remote Control Motor Light Garage Switch Work with Alexa
$12.61
Purchase Tips
For the device to connect to the mobile app, it must be paired with a supported Zigbee gateway, which needs to be purchased separately and can be linked with other compatible smart devices to realize automation scenarios.
Function
【APP Remote Control】
Require Tuya Zigbee Hub. You can check the working state of the device in Tuya APP anywhere and anytime.
【RF433mhz Control】
The device can be controlled by the RF433mhz Remote Controller.
【Mobile Phone Control】
Require Tuya ZigBee Hub ,when you go outside or at home, your smart phone could control the device by 2.4Ghz WIFI or 2G/3G/4G Mobile Network.
【Voice Control】
Require Tuya Zigbee Hub, you could voice control the device by Alexa/Google Assistant.
【Smart Linkage】
Cooperate with other zigbee products to achieve intelligent linkage. For example, with zigbee door magnetic sensing, to realize the light on immediately after opening the door
【Group Control】
Unified management of individual devices using gateways
【Timing function】
Lying in bed without turning off the lights fell asleep, it does not matter, the wall switch timing function to the point of turning off the lights, from the lights off do not worry about.
【Two Working Modes】
Self-locking, Inching
What can I use it for?
*Connect a light, remotely control the switch of the light.Connect a light, remotely control the switch of the light, and can also switch on and off regularly
19:00 On 21:00 Off
*Open your curtains regularly 7:00
*Change the water for the fish tank regularly
*Use mobile phone or voice control Garage door switch
*Control your heater remotely
*And your coffee machine
*Connect a water pump, remote control or timer switch
More functions waiting for you to discover. DIY
Checklist before using the device
You need to have a Zigbee gateway.
Try to be close to the Zigbee gateway when pairing.
Timing Function
you can the time to turn on lights and turn on the fans in the office
Remote control of garage door opening and closing
Group Control
Set all of your smart switches in a group by Smart Life app. Then one-click to turn/off all of your appliances or lightings by smartphone.
Hands-Free Voice Control
Compatible with Alexa & Google Home,the smart switch allows you to control lights on/off with your voice
Family Sharing
Share the control with family member.Enjoy the convenience and happiness together
English instructions
433MHz Remote Control:
Operating voltage: DC12V (27A/12V Without battery)
Transmitting frequency: 433MHz
Encoding Type: Learning code
Transmission distance : 10-100M (Open field)
Free screwdriver
FAQ
I don't have a gateway, can I connect directly to a wifi network?
Sorry, this one won't work, this one needs to be connected to a ZIGBEE gateway to work
How far away can the switch be connected to the gateway?
As indoor environments vary, the distance between the wireless switch and the gateway varies. Generally, the communication distance between the two is less than 20 metres and is better when no more than two walls are in between.
How many modes of switching are there?
Two types, Self-locking ,Inching
What app do I use?
Tuya /Smart life
I'm not a professional electrician, can I install it myself?
Yes, it is very easy to install, just follow the connection drawings and you are ready to go.
Do you have a switch for more channels?
Contact our customer service,We also have 2CH and 4CH 7-32V 85-250V
When is the order shipped and how long does it take to arrive?
We will ship your order within 24 hours of placing it (except for holidays). Normal shipping time is 25-60 days, except for special shipping methods.
