B29C-Tuya Zigbee Leak Sensor Water Leakage Detector Leakage Sensor Water Sensor Prevent Water Leakage for Smart Home
Water poof, water leak detection,The sensor can detect whether there are water leakage at the installation location. If this is found, the information will be pushed to the phone immediately
Easy to Install, The installation of the sensor is very simple, you can use adhesive taps to install at the location you need to install, please note that the installation location should be connected to the Zigbee Hub
Use Zigbee, Tuya Zigbee hub is required,The sensor uses Zigbee to communicate with the server for data. So it won't be disturbed by other WiFi devices. Its communication link is more stable and faster. And it not supported other zigbee hub
APP Remote Monitoring, The alarm information and records of the sensors are all stored on the server. This design allows us to monitor whether there is water in the home or office from any place through the smartphone. And can also share the control information of the device to others
Low battery consumption, The power consumption of the sensor in standby mode is very small, and one CR2032battery can be used for one year. And when it detects that the battery is low, it will remind you to replace the battery through the alarm message
Sensor Size:52.5x26.5x13 mm
Probe Cable:1.0 m
Working Voltage:DC3V (CR2032 Included)
Battery Life:Over 1 year (20 times/day)
Wireless Type:Zigbee IEEE802.15.4
Working Temp:0℃-+50℃
Color:As Shown
Material:ABS
Package Contents:
1 * Water Leak Detector
