Ball Valve Compatible with Ezlo Smart Water Shut-Off Valve
$64.95
Pick the size of your main water line
The ball valve goes on the cold-water inlet of your main line. Add the Ezlo Smart Water Shut-Off Valve on top for automatic shut-off
¾″
$64.95
Standard size for most residential water supply systems
- Model: EZLO-BV-0.75
- Part #: EKBVFFN075
- UPC: 850010800363
- Thread: ¾″ NPT, female on both ends
- Stock: In stock
1″
$89.95
For larger homes or higher water demand
- Model: EZLO-BV-1.00
- Part #: EKBVFFN100
- UPC: 850010800370
- Thread: 1″ NPT, female on both ends
- Stock: In stock
1¼″
$149.95
For large residential systems and commercial buildings that need higher water throughput
- Model: EZLO-BV-1.25
- Part #: EKBVFFN125
- UPC: 850010800387
- Thread: 1¼″ NPT, female on both ends
- Stock: In stock
We recommend a qualified professional to help you choose and install the correct valve size. The Ezlo Water Valve control module is not included
Lead-free brass
Meets NSF/ANSI 61 and the California AB1953 and Vermont S.152 lead-free rules
Standard NPT fittings
Female NPT threads on both ends fit industry-standard pipe for a straightforward install
Manual and automatic
Use the handle by hand, or let the Ezlo Smart Water Shut-Off Valve turn the water off for you
5-year limited warranty
Brass valve body built for long service on your main water line
Plumb it in now, add the smart valve later
Install the ball valve on the cold-water inlet during the plumbing phase of new construction, or retrofit it into an existing system. The Ezlo smart actuator and control module can then be added at trim-out, which makes the job easier for builders
Works with the Ezlo Smart Water Shut-Off Valve
Pick the valve on its own, or a kit with leak sensors
The custom-tailored ball valve is engineered to integrate effortlessly with the Ezlo Smart Water Shut-Off Valve, providing a reliable solution for regulating and shutting off water flow in your plumbing system. Whether you're looking to isolate specific sections of your water network or quickly halt water flow in emergencies, this ball valve delivers exceptional performance and responsiveness.
Featuring robust construction and durable materials, our ball valves ensure longevity and reliability, giving you peace of mind in your smart home setup.
| Manufacturer Part #: | EKBVFFN075, EKBVFFN100, EKBVFFN125 |
| UPC: | 850010800363, 850010800370, 850010800387 |
| Description: | Ball Valve 510L F/F NPT ¾” , 1’’ or 1¼“ |
| Warranty: | 5-Year Limited |
