Broadlink RM4 mini +HTS2 WiFi IR Remote Controller for Air conditioning TV set-top Box Temperature Humidity Sensor HTS2 Alexa
Universal Compatibility: This device functions as an IR remote control, allowing you to manage a wide range of infrared appliances through the Broadlink app
Voice Control Integration: Seamlessly compatible with Alexa and Google Assistant, it enables hands-free operation of your devices. For instance, you can turn your TV o..
Temperature and Humidity Monitoring: Equipped with the HTS2 sensor, it provides real-time data on your room's temperature and humidity levels, accessible via the Broad..
Scheduling and Timers: Set specific times for your appliances to operate, ensuring you never miss your favorite shows or experience discomfort due to temperature fluct..
The Broadlink RM4 Mini with HTS2 Sensor is a compact and versatile Universal Remote Control (IR) designed to streamline the management of your home appliances. By consolidating control of devices such as air conditioners, TVs, and set-top boxes into a single, user-friendly interface, it enhances your smart home experience.
- Universal Compatibility: This device functions as an IR remote control, allowing you to manage a wide range of infrared appliances through the Broadlink app.
- Voice Control Integration: Seamlessly compatible with Alexa and Google Assistant, it enables hands-free operation of your devices. For instance, you can turn your TV on or off or adjust the volume using simple voice commands.
- Temperature and Humidity Monitoring: Equipped with the HTS2 sensor, it provides real-time data on your room's temperature and humidity levels, accessible via the Broadlink app. This feature allows for automated scenes, such as activating your air conditioner when the temperature exceeds a certain threshold.
- Scheduling and Timers: Set specific times for your appliances to operate, ensuring you never miss your favorite shows or experience discomfort due to temperature fluctuations.
The Broadlink RM4 Mini serves as a centralized hub for controlling multiple devices, reducing the need for multiple remotes and simplifying your home environment. Its integration with voice assistants offers the convenience of hands-free control, enhancing daily routines. The temperature and humidity monitoring feature contributes to a comfortable living space by enabling automated climate control based on real-time data.
Additional Information
Setting up the Broadlink RM4 Mini is straightforward. After connecting it to your Wi-Fi network, you can configure and manage your devices through the Broadlink app. Regular firmware updates ensure compatibility with a growing list of appliances and maintain optimal performance.
Incorporating the Broadlink RM4 Mini with HTS2 Sensor into your home automation system offers a seamless and efficient way to control your infrared appliances, enhancing both convenience and comfort.
Model
RM4 mini
Material
Infrared transmission material
Power Input
DC 5V 1A (Micro USB)
Infrared Direction
Multiple-direction infrared
Infrared Frequency
38KHz
Communicaiton Mode
Wi-Fi 802.11b/g/n(2.4GHz)
Supported OS
Android 4.0 / iOS 9.0 and above
Adaptor Types
No adapter in package, Compatible with all 5V USB adapters
Certification
CE
ROHS
Contains FCC ID: 2ACDZ-BL3336-P
Dimension(mm/pc)
85*50*65
