Broadlink RM4 Pro / RM4C Mini Universele IR RF Remote Control Afstandsbediening Compatibel Alexa Google Assistent For Ac
Universal Compatibility: Supports a vast array of IR-controlled devices such as TVs, set-top boxes, air conditioners, and fans, as well as RF-controlled devices like c..
Voice Control Integration: Compatible with Amazon Alexa and Google Assistant, allowing you to control your devices using simple voice commands
Broad IR Coverage: Equipped with multiple IR transmitters that cover a 360° range, ensuring reliable control of your devices from various angles
Mobile App Control: Manage your devices remotely via the BroadLink app, available on both iOS and Android platforms. The app offers intuitive configuration and scene c..
Learning Function: If certain devices are not present in the cloud database, the RM4 Pro can learn their IR codes, ensuring compatibility with a wide range of appliances
The Broadlink RM4 Pro is a versatile universal remote control that consolidates your home entertainment and smart devices into a single, user-friendly interface. Designed to replace multiple remotes, it offers seamless control over a wide range of appliances, enhancing convenience and efficiency in your daily life.
The Broadlink RM4 Pro is a smart universal remote that enables you to control various devices, including TVs, air conditioners, fans, and more, through your smartphone or voice commands. It supports both infrared (IR) and radio frequency (RF) signals, making it compatible with over 50,000 devices. This extensive compatibility ensures that your existing appliances can be integrated into your smart home setup without the need for additional remotes.
- Universal Compatibility: Supports a vast array of IR-controlled devices such as TVs, set-top boxes, air conditioners, and fans, as well as RF-controlled devices like curtain motors and light switches.
- Voice Control Integration: Compatible with Amazon Alexa and Google Assistant, allowing you to control your devices using simple voice commands.
- Broad IR Coverage: Equipped with multiple IR transmitters that cover a 360° range, ensuring reliable control of your devices from various angles.
- Mobile App Control: Manage your devices remotely via the BroadLink app, available on both iOS and Android platforms. The app offers intuitive configuration and scene creation features.
- Learning Function: If certain devices are not present in the cloud database, the RM4 Pro can learn their IR codes, ensuring compatibility with a wide range of appliances.
To set up the Universal Remote RM4 Pro, connect it to your home Wi-Fi network (2.4 GHz only) and pair it with the BroadLink app. Once connected, you can add your devices by selecting them from the app’s extensive database or by using the learning function for unsupported devices. After setup, control your devices through the app or by issuing voice commands via Alexa or Google Assistant.
- Simplified Control: Eliminates the need for multiple remotes, streamlining your home entertainment and smart device management.
- Enhanced Convenience: Allows you to control your devices remotely, ensuring your home is always comfortable and ready for you.
- Future-Proof: The cloud-based database is regularly updated, ensuring ongoing compatibility with new devices and technologies.
In summary, the Broadlink RM4 Pro remote is a powerful and flexible universal remote control that integrates seamlessly into your smart home ecosystem, offering enhanced control, convenience, and compatibility.
