BroadLink RM4 Pro+HTS2 IR RF Version Wireless Universal Remote Hub with Temp and Humidity Sensor Smart Home Solution
Universal Compatibility: The RM4 Pro+'s dual IR/RF capabilities ensure it can communicate with a vast array of devices, making it an all-in-one solution for your home ..
WiFi Connectivity: With integrated WiFi, you can control your appliances remotely via the BroadLink app, providing convenience whether you're at home or away
Voice Control Integration: Compatible with Amazon Alexa and Google Assistant, the RM4 Pro+ allows for hands-free operation of your devices through simple voice commands
Temperature and Humidity Monitoring: Equipped with an external USB sensor cable, it monitors room temperature and humidity, allowing you to create environment-based au..
Shop BroadLink RM4 Pro+ HTS2 RF WiFi Universal Remote And Home Automation
The BroadLink RM4 Pro+ HTS2 is a versatile Wireless Universal Remote that consolidates control over your home's electronic devices into a single, user-friendly interface. Supporting both infrared (IR) and radio frequency (RF) signals, it enables seamless management of a wide range of appliances, including TVs, air conditioners, and set-top boxes. With its advanced features, it also serves as an ideal RF WiFi Universal Remote for modern smart homes.
- Universal Compatibility: The RM4 Pro+'s dual IR/RF capabilities ensure it can communicate with a vast array of devices, making it an all-in-one solution for your home automation needs.
- WiFi Connectivity: With integrated WiFi, you can control your appliances remotely via the BroadLink app, providing convenience whether you're at home or away.
- Voice Control Integration: Compatible with Amazon Alexa and Google Assistant, the RM4 Pro+ allows for hands-free operation of your devices through simple voice commands.
- Temperature and Humidity Monitoring: Equipped with an external USB sensor cable, it monitors room temperature and humidity, allowing you to create environment-based automations for enhanced comfort.
- Simplified Control: Replace multiple remotes with the RM4 Pro+ to streamline your home entertainment system, reducing clutter and simplifying device management.
- Remote Accessibility: Control your appliances from anywhere using the BroadLink app, ensuring your home is always set to your preferences, even when you're away.
- Enhanced Automation: Utilize the temperature and humidity sensor to set up automated routines, such as adjusting your air conditioner based on room conditions, enhancing comfort and energy efficiency.
- Voice-Activated Convenience: With Alexa and Google Assistant compatibility, adjust your devices effortlessly using voice commands, adding a layer of convenience to your daily routines.
Designed for ultimate functionality, this RF WiFi Universal Remote also integrates seamlessly into your Smart Home Automation system, offering centralized control and efficiency. Transform your living space with the BroadLink RM4 Pro+ HTS2—a smart hub built for convenience, flexibility, and control.
