Ewelink Zigbee 3.0 Water Sensor Alarm, Leak Detector & Warning Device, Easy Lnstallation For Home Flood Safety Alert System
Zigbee 3.0 Compatibility: Utilizing the latest Zigbee 3.0 protocol, this sensor ensures stable and efficient communication with your Zigbee gateway, enhancing the reli..
Precision Detection: Equipped with advanced sensing technology, the Ewelink Water Leak Sensor accurately detects even minimal moisture presence, promptly triggering al..
Instant Notifications: Upon detecting a leak, the sensor sends immediate push notifications to your smartphone via the eWeLink app, ensuring you can respond quickly wi..
Seamless Integration: Compatible with various smart devices and platforms, including Google Assistant, this sensor allows for the creation of customized automation sce..
Compact and Flexible Design: Its sleek, compact form factor and flexible mounting options allow for discreet placement under sinks, near water heaters, or in any other..
Shop Ewelink Zigbee 3.0 Water Leak Sensor With Reliable Water Leak Detector Alarm
Protect your home from unexpected water damage with the Ewelink Zigbee 3.0 Water Leak Sensor. This advanced device integrates seamlessly into your smart home ecosystem, providing real-time monitoring and instant alerts to ensure comprehensive protection against leaks and floods.
- Zigbee 3.0 Compatibility: Utilizing the latest Zigbee 3.0 protocol, this sensor ensures stable and efficient communication with your Zigbee gateway, enhancing the reliability of your Wireless Water Leak Alarm System.
- Precision Detection: Equipped with advanced sensing technology, the Ewelink Water Leak Sensor accurately detects even minimal moisture presence, promptly triggering alerts to prevent potential water damage.
- Instant Notifications: Upon detecting a leak, the sensor sends immediate push notifications to your smartphone via the eWeLink app, ensuring you can respond quickly with a Water Leak Detector Alarm.
- Seamless Integration: Compatible with various smart devices and platforms, including Google Assistant, this sensor allows for the creation of customized automation scenarios within your Wireless Water Leak Alarm System.
- Compact and Flexible Design: Its sleek, compact form factor and flexible mounting options allow for discreet placement under sinks, near water heaters, or in any other vulnerable areas without compromising aesthetics.
- Low Battery Alert: The sensor features a low battery warning system, automatically notifying you when it's time to replace the batteries, ensuring continuous and reliable operation.
The Ewelink Water Leak Sensor is ideal for monitoring areas prone to leaks, such as bathrooms, kitchens, basements, and laundry rooms. By integrating this sensor into your Wireless Water Leak Alarm System, you can prevent costly repairs and maintain a safe living environment. The device's real-time monitoring and instant alert capabilities empower you to respond promptly to potential water hazards with a Water Leak Detector Alarm, providing peace of mind and safeguarding your property.
Specifications
- Input Voltage: 3V (LR03 AAA battery, not included)
- Communication Protocol: Zigbee 3.0
- Dimensions: Main body: 69.5 x 24 x 18.5 mm
Package Includes
- 1 x Ewelink Zigbee 3.0 Water Leak Sensor
- 1 x Double-sided Tape
- 1 x User Manual
