Ewelink Zigbee3.0 Water Sensor Alarm Water Leak Detector Flood Alert Overflow Security Alarm System Works With Zigbee Gateway
Zigbee 3.0 Compatibility: Utilizing the Zigbee 3.0 protocol, this detector ensures stable and efficient communication with compatible hubs or gateways, enhancing the r..
Shop Ewelink Zigbee 3.0 Water Leak Detector Stay Alert with Instant Water Leak Notifications
Protect your home from unexpected water damage with the Ewelink Zigbee 3.0 Water Leak Detector. This advanced device serves as a reliable Flood Alert Sensor, ensuring you're promptly notified of any water leaks or overflows. Designed to integrate seamlessly with your Zigbee-based smart home system, it offers real-time monitoring and immediate alerts to keep your property safe with an effective Overflow Security Alarm.
- Zigbee 3.0 Compatibility: Utilizing the Zigbee 3.0 protocol, this detector ensures stable and efficient communication with compatible hubs or gateways, enhancing the reliability of your Overflow Security Alarm system.
- High Sensitivity Detection: Equipped with dual sensitive probes, the sensor can detect water levels as low as 0.5mm, providing an early warning to prevent potential water damage.
- Instant Notifications: Receive real-time alerts on your smartphone through the eWeLink app whenever a leak is detected, allowing you to take swift action to mitigate damage.
- IP66 Waterproof Rating: Built to withstand humid environments, the sensor's IP66 rating ensures durability, making it ideal for placement near dishwashers, water heaters, or washing machines.
- Easy Installation: With its compact design and included double-sided tape, setting up your Smart Water Leak Alarm is straightforward and tool-free.
The Ewelink Zigbee 3.0 Water Leak Detector is perfect for monitoring areas prone to leaks, such as bathrooms, kitchens, basements, or nearby appliances like washing machines and water heaters. By providing immediate alerts, this Flood Alert Sensor helps you address issues before they escalate, potentially saving you from costly repairs and extensive water damage. Additionally, its Overflow Security Alarm function adds an extra layer of protection against accidental flooding.
Specifications
- Power Supply: 1 x CR2032 battery (not included)
- Operating Temperature: -20°C to 60°C
- Dimensions: 37 x 37 x 8 mm
- Waterproof Grade: IP66
