Ewelink Zigbee3.0 Water Sensor Alarm Water Leak Detector Flood Alert Overflow Security Alarm System Works with Zigbee Gateway
• Zigbee3.0 Technology :The Ewelink Zigbee3.0 Water Sensor Alarm leverages the latest Zigbee3.0 technology, ensuring reliable and efficient communication with the Zigbee Gateway for real-time alerting.
• Flood Alert Feature :This device features a flood alert system that promptly notifies you of any water overflow, protecting your home from potential flood damage.
• Security Alarm System :The security alarm system integrates seamlessly with your Google Assistant, providing you with a comprehensive and convenient way to monitor your home's water security.
• Rohs Certified :With RoHS certification, this product guarantees low levels of harmful substances, prioritizing both your safety and the environment.
• Easy Installation :Designed for user-friendly installation, this water sensor alarm can be easily set up in your desired location, providing round-the-clock monitoring.
• Long-lasting Performance :The Ewelink Zigbee3.0 Water Sensor Alarm offers long-lasting performance, ensuring continuous protection for your home against water-related issues.
Ewelink Zigbee3.0 Water Sensor Alarm Water Leak Detector Flood Alert Overflow Security Alarm System Works With Zigbee Gateway
Tips for purchase: This product is Zigbee version, Users must have/already bought a zigbee hub to operate. If without a zigbee hub, then such model will not work.
Product Description:
Experience unparalleled peace of mind with the Ewelink Zigbee 3.0 Water Leak Detector, a cutting-edge smart sensor designed to safeguard your home against costly water damage. Integrating seamlessly with your Zigbee-based smart home ecosystem, this device offers real-time monitoring, instant alerts, and comprehensive control over potential water leaks.
Key Features:
1.Zigbee 3.0 Compatibility:Built on the reliable and energy-efficient Zigbee 3.0 protocol, this detector flawlessly connects to compatible hubs, routers, or gateways, ensuring smooth integration into your existing smart home network.
2. Precision Detection: Equipped with advanced sensing technology, the sensor accurately detects even the slightest water presence, promptly triggering alerts when moisture levels exceed a predetermined threshold.
3. Instant Notifications: In the event of a leak, you'll receive instant push notifications directly to your smartphone via the Ewelink app, empowering you to take swift action and mitigate potential damages.
4 .User-friendly App Control: Monitor the status of your water leak detector, view historical data, and manage settings effortlessly through the intuitive Ewelink mobile app, available for both iOS and Android devices.
5.Low-profile Design: With its sleek, compact form factor and flexible mounting options, the detector can be inconspicuously placed under sinks, near water heaters, or in any other vulnerable areas without compromising aesthetics.
6.Low Voltage Remind:When the battery level is low, it will automatically remind you to change batteries, never worry about running out of battery.
nput voltage:3V LR03
Quiescent Current:≤10uA
Alarm Current:≤15mA
Low power undervoltage:≤2.5V
Zigbee: Zigbee3.0
Battery: DC 3V LR03(AAA battery,not included)
Size: Main body: 69.5*24*18.5mm
Product package included:
1xSensor (Not include battery)
1xDouble sided Tape
1xUser manual
Product Image:
