Ewlink Zigbee Motion Sensor Wireless Motion Detector Get Alerts or Trigger Lights to Turn on Zigbee Bridge Hub Required
Requires Hub:Requires Zigbee Hub. without Zigbee Hub, this smart motion sensor will not work. Please search B0BRZZBX6Y or B0C85RNQXF to get the hub
Security Monitoring:With 120° wide angle coverage, 360° surround, and 20 feet detection range, it will detect any motion around your home. Also, you will receive alert..
Smart Light Control: If you have a smart light or smart plug connected to eWeLink APP, you can create linkage in eWeLink APP to automatically turn on the light when th..
Application scenarios: Not only can the motion sensor trigger Hub alerts when motion is detected, it can also be connected to other devices to set more personalized sc..
Link a camera to the motion sensor and place it almost anywhere home, then you can view what's going on in your home through the camera on the sensor page of APP
Requires Hub:Requires Zigbee Hub. without Zigbee Hub, this smart motion sensor will not work. Please search B0BRZZBX6Y or B0C85RNQXF to get the hub.
Security Monitoring:With 120° wide angle coverage, 360° surround, and 20 feet detection range, it will detect any motion around your home. Also, you will receive alerts from the app when someone passes by.
Smart Light Control: If you have a smart light or smart plug connected to eWeLink APP, you can create linkage in eWeLink APP to automatically turn on the light when the motion sensor detects motion
Application scenarios: Not only can the motion sensor trigger Hub alerts when motion is detected, it can also be connected to other devices to set more personalized scenarios. For example, the motion sensor's night light mode will help you automatically turn on lights when you pass by stairs, kitchens, hallways, bedrooms, etc. at night, bringing safety and convenience to you and your family.
Link a camera to the motion sensor and place it almost anywhere home, then you can view what's going on in your home through the camera on the sensor page of APP.
