21 Thermostats already found their owners
See the difference
Ezlo Other Brands
Local Automation
Yes No
Works Offline
Yes No
Multi-Device Automations
Yes Limited
No Subscriptions
Yes No
Ezlo Z-Wave ThermostatModel EZL-TSTAT-US
Stop $1,000+
in wasted energy before it hits your bill
$129.95
Bundle DealsIn Stock
1 pack
$129.95
SAVE $69.90
3 packs
$319.95
SAVE $149.80
5 packs
$499.95
  • Effortless Device Control
  • Voice Control via an application
  • Connectivity with Multiple Radio Frequencies and Devices
  • Seamless Automation with MeshBots via MiOS
System Compatibility
Controls up to 3 stages heating and 2 stages cooling
8 types of control systems
EM heat activation
Adjustable compressor delay time, O/B changeover
Applies for regular AC or heat pump systems (gas/fuel boiler, electric heating, water heating)
Power Supply
AC/DC 24V
4 "AAA" dry batteries (low power working state)
Power input range: 20-28VAC
Wiring
Wiring for Conventional Systems and Heat Pump Systems
Various wiring configurations for different stages and setups (single and double transformers)
Functions & Settings
Setpoint Setting
Mode Setting (OFF, HEAT, COOL, AUTO, AUX/emergency heating)
Fan Mode & Schedule Setting (Fan On, Fan Auto)
Standby & Backlight Brightness Setting
Schedule Function (can be enabled/disabled)
Secret Menu for advanced settings
Display & Controls
Frameless Display
Touch button operation
Technical Parameters
Self-Consumption: <1W
Resistive Load: <1A
Temperature Setting Range: 0~40°C (32~99°F)
Precision: 0.1°C (1°F)
Outcase: PC+ABS
Wire Connection: Terminal
Dimensions: 113 × 113 × 19 mm
Installation: 60.3mm hole pitch
Compliance
CE Declaration of Conformity (Directive 2014/53/EU)
WEEE Directive Compliance
Connectivity
Z-Wave 800 series
Z-Wave frequency defined by regulatory bodies (for Z-Wave in Europe: 868.0-868.6 MHz, 869.7-870.0 MHz)
Support S2 function
Z-Wave Plus compatible
CERoHSZ-Wave PlusFCCULWEEE
Ezlo Thermostat display overview — schedule, temperature and mode indicators
Electrical Installation: Turn off power to your HVAC system at the circuit breaker before installation. If you are not comfortable working with thermostat wiring, consult a qualified HVAC technician
Indoor Use Only: Designed for indoor environments. Keep away from water, condensation, and direct heat sources for accurate readings and safe operation
Experience the perfect fusion of technology and comfort with the Ezlo Thermostat. Seamlessly integrating Z-Wave connectivity, a sleek user interface, and precise temperature control, our thermostat empowers you to modernize your home’s heating and cooling system effortlessly. Create custom schedules, adjust settings remotely, and even receive alerts if temperatures fall outside of your desired range*
Universal Z-Wave Connectivity
Seamlessly pairs with Ezlo, SmartThings, Hubitat, and other Z-Wave hubs for effortless smart home integration
Broad HVAC Compatibility
Supports both heat pumps and traditional AC units with up to two distinct heating and cooling stages
Touch-Sensitive Interface
Features a sleek, touch-responsive surface for quick and precise temperature adjustments without physical buttons
Smart Automation & Remote Control
Easily create custom schedules, monitor energy use, and manage your climate settings anytime via the MiOS app
Ezlo Z-Wave Thermostat on a living room wall
Smart. Convenient. Efficient
Modernize your home climate with the Ezlo Thermostat — the perfect blend of technology and comfort. Featuring Z-Wave connectivity, precise temperature control, and a sleek touch interface, it lets you set custom schedules, adjust settings remotely, and receive instant alerts if temperatures shift. Upgrade today for effortless smart control!
Universal HVAC Compatibility
Modernize your home heating and cooling with seamless support for heat pumps and multi-stage AC systems
Smart Home Automation
Create custom schedules, monitor energy use, and trigger MeshBot automations based on temperature
Easy Pairing
Connects to the MiOS mobile app and your Z-Wave hub in minutes for quick, hassle-free setup
Z-Wave Plus Connectivity
Pairs with Ezlo, SmartThings, Hubitat, and other Z-Wave hubs for effortless integration
Child-Safe Lock Mode
Prevents accidental or unwanted setting changes to keep your home climate stable and your setup secure
Effortless Installation
Simple terminal wiring with a standard 60.3mm hole pitch — replaces your old thermostat in minutes
Works With Your Smart Home
The Ezlo Thermostat is a Z-Wave Plus certified device — it plugs straight into the smart home you already have
Universal Z-Wave ConnectivityPairs with Ezlo, SmartThings, Hubitat, and other Z-Wave hubs for effortless integration
Home Assistant ReadyWorks with Home Assistant through any supported Z-Wave controller for advanced local automations
MiOS App ControlSet schedules, adjust temperature, and get instant alerts from your iPhone or Android anywhere
Child-Safe Mode for Peace of Mind Child-Safe Mode for Peace of Mind
The Ezlo Thermostat includes a child-lock feature that prevents accidental or unwanted changes to temperature settings—keeping your home environment stable and your settings secure. Perfect for families with curious little ones!
Works with Your HVAC System Works with Your HVAC System
Comprehensive compatibility with your existing HVAC system, allowing you to seamlessly control both heat pumps and traditional AC units. It is equipped to handle modern heating and cooling setups, supporting up to 2 distinct stages for heating and cooling.
Touch Sensitive Controls Touch Sensitive Controls
The smooth, touch responsive surface allows for precise input and quick adjustments, making it easy to access your features and settings providing a modern and convenient user experience, eliminating the need for physical buttons and dials
Frequently Asked Questions
Q: Do I need a hub to use this thermostat?
A: Basic manual control works right on the touch interface. All automation, remote access, and app-based configuration require pairing with a Z-Wave hub — ideally Ezlo Plus.
Q: Which HVAC systems does it support?
A: The thermostat supports both heat pumps and traditional AC units with up to two distinct heating and two cooling stages, covering the vast majority of home HVAC setups.
Q: Is it compatible with Home Assistant?
A: Yes. As a standard Z-Wave Plus device it works with Home Assistant through any supported Z-Wave controller, enabling advanced local automations and full control of your smart home ecosystem.
Q: Can I create heating and cooling schedules?
A: Yes. Through the MiOS app you can create custom schedules, monitor energy use, adjust settings remotely, and receive alerts if temperatures fall outside your desired range.
Q: What is the child-safe lock mode?
A: Lock mode disables the touch interface so accidental or unwanted presses cannot change your settings. You keep full control from the app while the wall unit stays protected.
Q: How is my data and privacy protected?
A: We prioritize data sovereignty. Ezlo devices utilize a US-Based Cloud — your data remains secure and is hosted entirely on compliant servers within the United States.
A: We are here to help! For any additional questions or technical assistance, please contact our customer care team at 866-966-2272 or email us at support@ezlo.com.
Download on App Store App Store QR
Get it on Google Play Google Play QR
Frequently Bought Together
Ezlo Plus Smart
Home Hub
Ezlo Plus Smart
Home Hub
$ 179.95
Shop now ›
Ezlo Smart Z-Wave LED Bulb
$ 10.00
Shop now ›
Ezlo Smart Doorbell Camera
$ 179.97
Shop now ›
Trusted Around the World
What's New at Ezlo
