Make it part of your Ezlo AI homeVoice and chat control. Helpful automations. One connected home
About this item
  • • AI-READY THE MOMENT YOU PLUG INPreloaded Christmas scenes light up instantly, with the Ezlo AI app ready to take your display further.
  • • STRAIGHT TO AI, NO HUB NEEDEDConnects directly to 2.4 GHz Wi-Fi. No extra hardware between you and AI control.
  • • AI THAT RUNS YOUR LIGHTSThe Ezlo AI app handles scenes, brightness and schedules, so your display runs itself all season.
  • • TALK TO YOUR LIGHTSAI voice control through the Ezlo AI app. Say it, and your lights respond.
  • • AI AUTOMATION WITH MESHBOTSEzlo AI MeshBots link your lights to your smart home for intelligent, hands-free holiday automation.
AI Addressable LED Wifi Indoor Christmas Strip Light All-in-one RGBCCT COB Kit
Start with Christmas lights. Build a smarter home
Transform your home with brilliant colors, beautiful lighting effects, and smart automation. Control your lights from the Ezlo app, create schedules, and discover how easy a smarter home can be
$49
For indoor use only
Only 10 left in stock - order soon
  • Free Shipping over $50
Choose the perfect length for your indoor spaceIn Stock
9.8 packs
$49
16.4 packs
$69
24 packs
$89
  • Effortless Device Control
  • Voice Control via the Ezlo app
  • Wi-Fi 2.4 GHz Connectivity
  • Seamless Automation with MeshBots via the Ezlo app
Each kit is a complete addressable LED set: strip, Wi-Fi controller and power supply. It's wired, flashed and tested at our warehouse before it ships. There's no hub to buy, nothing to solder and no wiring to do. Plug the power supply into a wall outlet, add the kit in the Ezlo app and the lights are ready
The strip is RGBCCT. Every segment carries red, green and blue plus warm and cool white, so it does full color and clean white. Each segment is controlled on its own, which is what lets colors chase, fade and blend along the strip
The controller connects to your home Wi-Fi (2.4 GHz). From the Ezlo app you can turn the lights on and off, change color, brightness and effects, and run them on schedules and automations with your other Ezlo devices
Kit9.8 ft (3 m)16.4 ft (5 m)24 ft (7.3 m)
Power supply24 V, 48 W24 V, 72 W24 V, 120 W
TypeWall plug-in adapterWall plug-in adapterDesktop power brick with a power cord
Size3.2 × 1.9 × 1.3 in (81 × 48 × 33 mm)3.7 × 1.9 × 1.3 in (94 × 48 × 34 mm)6.7 × 2.6 × 1.5 in (170 × 65 × 39 mm)
Cables3.9 ft (1.2 m) DC cable3.9 ft (1.2 m) DC cable3.6 ft (1.1 m) DC cable, 3.9 ft (1.2 m) power cord
All kits
Strip
WS2811 addressable RGBCCT COB, 24 V DC, 840 LEDs per meter, dotless light
Segment length
2.8 in (71.5 mm)
Rating
IP30, indoor use only
Controller
Wi-Fi LED controller, 24 V DC input
Wi-Fi
2.4 GHz
Power supply input
100–240 V AC, 50/60 Hz
Power supply
ETL listed Class 2, 5.5 × 2.1 mm DC plug, protected against over-current, over-voltage, overload, short circuit and overheating
App
Ezlo AI app (iPhone)
In the box
LED strip, Wi-Fi controller, 24 V power supply, quick start guide
1 year
  • For indoor use only. The strip is rated IP30 and the controller and power supply are not waterproof. Keep every part away from rain, snow, moisture and wet surfaces
  • Use only the power supply that comes in the box. It's sized for your kit's length. Don't connect extra strips or extend the strip
  • Don't cut, splice or re-solder the strip. The kit is wired and flashed at the factory, and changes can damage it or create a fire risk
  • Let it breathe. Don't use the strip coiled on its reel, covered, or behind insulation. Mount it on a clean, dry, non-flammable surface
  • Check before use. If the strip, cable, controller or power supply is damaged, unplug it and don't use it
  • Unplug before handling. Disconnect the power supply from the outlet before you install, move or clean the lights
  • Not a toy. Keep small parts and cables away from children and pets
Everything you need to set up and use your kit: what's in the box, how to mount the strip, how to add the kit in the Ezlo app, how to pick scenes and colors, and what to do if the lights don't respond. The same guide opens from the QR code on the quick start card in the box
Make This Christmas Glow 🎄
Tap a preset to preview it. In the Ezlo app, ask Ezlo AI by voice or text to create your own effect
Ask Ezlo AIMake a slow red-and-white candy cane effect
Christmas presets
  • Plug & Play Setup
    The strip, controller and power supply come connected. Plug it in and the lights come on
  • AI Controlled
    Ask Ezlo AI for a new light show by voice or text, in your own words
  • Ezlo App Control
    Turn the lights on and off, change scenes and set the brightness from your phone
  • Christmas Scenes Loaded
    Classic Christmas, Candy Cane, Snowfall and Festive Rainbow are ready out of the box
  • Millions of Colors
    Pick any color, or let the scenes blend them for you
  • Color by Segment
    Colors change segment by segment, every 2.8 in (71.5 mm), plus warm and cool white, so effects chase along the strip
Bring your holiday lighting
to life with Ezlo AI
Ask for a light show in your own words, by voice or text, and Ezlo AI turns it into an effect on your strip. Or start with one of the Christmas scenes that come loaded
Ezlo app: the LED strip screen with colors, moods and effects
The same room at night, the couple asleep in warm, dimmed light A couple on the sofa watching TV in a room lit by LED strips
  • Turn On at sunsetScene: Classic Christmas4:32 PM
  • Turn Off at bedtimeFade out over 5 minutes10:30 PM
Your Christmas Lights
On Autopilot
Turn on Classic Christmas at sunset and switch the lights off at bedtime. Set the schedule once in the Ezlo app
A cut-away flat at Christmas: a lit tree, a couple on the sofa, bedroom, kitchen and balcony
Christmas Is Just
the Beginning
No hub needed: the strip connects straight to your Wi-Fi and into the Ezlo AI app. Ready for more? Add Ezlo sensors, switches and plugs anytime, and let AI run your whole home from one app.
  1. Start with Christmas lights
  2. Sync your tree and strip on one AI schedule with a compatible smart plug
  3. Grow your AI smart home with more Ezlo devices
  4. Control it all with Ezlo AI, in one app
Each kit includes
  • Addressable RGBCCT LED strip
    9.8 ft, 16.4 ft or 24 ft, by the kit you pick
  • Wi-Fi LED controller
    Wi-Fi controller with the Christmas scenes loaded
  • 24 V power supply
    24 V power supply
    48 W, 72 W or 120 W, by the kit you pick
  • Quick start guide
    Quick start guide
    From the box to a lit room in a few minutes
Which length is right for you?
Measure the mantel, bookshelf, indoor window frame or TV console you want to light and pick the kit that covers it
9.8 ft (3 m)$49Perfect for shelves, windows, and small indoor displays24 V, 48 W power supply
16.4 ft (5 m)$69Ideal for a TV area, a workspace and room accents24 V, 72 W power supply
24 ft (7.3 m)$89Great for larger indoor displays and festive room decorations24 V, 120 W power supply
Frequently Asked Questions
Q: Which length should I choose?
A: Measure the mantel, bookshelf, indoor window frame or TV console you want to light. The kits come in 9.8 ft (3 m), 16.4 ft (5 m) and 24 ft (7.3 m)
Q: What's in the box?
A: The LED strip, a Wi-Fi LED controller, a 24 V power supply sized for the kit and a quick start guide. Everything comes connected
Q: Do I need to set anything up?
A: No. The Christmas scenes come loaded, so the lights work as soon as you plug them in. Plug it in, add it in the Ezlo app, and pick a scene
Q: How do I change the effects?
A: Pick a scene in the Ezlo app, or ask Ezlo AI by voice or text, for example "Make it more festive"
Q: How is my data and privacy protected?
A: We prioritize data sovereignty. Ezlo devices utilize a US-Based Cloud — your data remains secure and is hosted entirely on compliant servers within the United States
A: We are here to help! For any additional questions or technical assistance, please contact our customer care team at 866-966-2272 or email us at support@ezlo.com
Trusted Around the World
What's New at Ezlo
New this season: Ezlo Protect for iOS, Android, built-in tablets, iPad and Apple Watch, the Ezlo AI app for iOS, the Christmas LED Strip Kit, Ezlo Sense health-aware sensing, Centralite Zigbee sensors, Frankever Wi-Fi switches and dimmers, and the Ezlo Water Valve Kits
