Home Security for Smart Home Smart Life APP Zigbee 3.0 Tuya Door Sensor Window Sensor Compatible with Alexa Google Assistant
NOTE:
1. The product is not waterproof, Not suitable for outdoor use.
2. Zigbee Version required Zigbee Hub to work together.
Product Features:
1. Instant Notification
Push instant notification to your phone immediately when door or window is opened or closed. Keeping you informed all the time.
2. Alarm Alert
Whenever the sensor is triggered to open/close, it will send alarm to alert you that someone opens your door or window.
3. Alarm Recording
Support checking open / close records and battery level on the app. Never worry about missing any important moments or running out of battery.
4. Device Share
Select "Home Management" in the "Me" page to share your added sensors with family members. so that they can also monitor the status of doors/windows.
5. Low Voltage Remind
When battery level is low, it will automatically remind you to change batteries, never worry
about running out of battery.
Product Parameter:
Battery: CR2032 ( included)
Battery Life: 10000 times trigger
Wireless Type: Zigbee3.0
App: Smart Life / Tuya Smart
Material: ABSSize:
(Main body): 52.5mm x 26.5mm x12.9mm
(Small body): 34.5mm x 12.5mm x 12.7mm
APP Remote Monitor:
1, Share Devices to your Family
2, Remote monitor Anywhere and Anytime
3, Cloud Event Record
Safeguard your home
1, Real Time Alert and Notification
2, Open or Close Detection
3, 7*24 Protection
Detect Open/Close status
When you leave home, it will push notification to you if the doors or windows are opened or invaded by an external object, you will find anomalies in your home immediately.
Where to install
1, Doors, windows, drawers, mailboxes, garages, cabinets, as long as there is any place to open and close. But please note that the equipment is not waterproof, please be indoors or where the water is not drenched.
2, It can protect your home, business, or anywhere Wi-Fi can reach.
Long Battery Life & Easy Battery Replacement
1, Long Battery Life 10000 Times trigger
2, Low Battery Remind. Don't worry about forgetting
3, The battery can be replaced with a push without any tools anybody.
Voice Control
Works with Amazon Alexa, Google Assistant
By connecting App to Amazon Echo, Google Home, you are able to voice control your home appliances. For example:
-Alexa, Is my front door locked?;
-Yes . the front door is locked
How to install
1.here are adhesive taps in the package. You can use them to install anywhere you want. They are very firm. Please don't worry.
2.Make both bodies as close as possible, the gap between two bodies is <10mm.
What is Included
1.Main Body
2.Small Body
3.Adhesive taps Kit(Screw installation kit not included)
4.English User Manual
APP Main Page & Setting Page Show
The page might get better.
APP Scenes & Automation Page Show
FQA
Q: What are the necessary conditions for using it?
A: Firstly, you must have a smartphone to install the app. Secondly, you need Tuya Zigbee Hub or Tuya Multi-mode Gateway.
Q: Can I control it through 2G, 3G, 4G, 5G mobile networks?
A: YES. Operating Smart IR Remote through APP means that as long as your mobile phone can access the Internet (no matter what communication mode), APP can control it. But sensor also needs to be constantly online through Zigbee Hub.
Q: What do I need to pay attention to when installing it?
A: 1. Please ensure that the Zigbee signal at the installation location is good. 2 . The product is not waterproof and can only be used indoors. 3. The product is not waterproof and needs to be installed indoors.
Q: Can multiple people use it?
A: YES. There are two methods: 1. You can use the sharing function to share with your friends or family. 2. You can create a virtual homeon the app and invite your family or friends to join.
Q: How should I configure my Smart Speaker / Amazon Alexa / Google Home / Yandex Alice ?
A: The Sensor cannot directly connect to third-party smart speakers. They need to provide account links and support through the "Skill" function. You can use the following methods: Smart Life ->Me ->Third Party Services. But the necessary condition for these is that you have already configured the sensor to Smart Life.
Q: Why are third-party pages different from Smart Life pages?
A: We are using Tuya's solution, and the pages on Smart Life are customized. But neither we nor Tuya can customize third-party pages, we can only use their internal default page display
