INKBIRD IBT-26S WiFi Kitchen Digital Cooking Thermometer Meat Food Temperature For Oven BBQ Grill Timer Function With 4 Probes
Simultaneous Monitoring with Multiple Probes: Equipped with up to six color-coded, food-grade stainless steel probes, the INKBIRD Digital Meat Thermometer allows for a..
User-Friendly App Control: The accompanying app provides access to 23 USDA preset meat options, making it ideal for both beginners and seasoned chefs. Customize high/l..
Rechargeable Long-Lasting Battery: Featuring a built-in 2500mAh lithium battery, the thermometer operates continuously for up to 32 hours on a single 3.5-hour full cha..
Convenient Design Elements: The backlit LCD screen with adjustable brightness ensures clear visibility in any lighting condition. Its magnetic back and foldable stand ..
The INKBIRD IBT-26S WiFi Thermometer is a versatile and smart cooking companion designed to elevate your culinary experience. With dual 5GHz/2.4GHz WiFi and Bluetooth 5.1 connectivity, this thermometer ensures stable and efficient monitoring of your cooking process, allowing you to check real-time temperatures remotely via your smartphone.
- Simultaneous Monitoring with Multiple Probes: Equipped with up to six color-coded, food-grade stainless steel probes, the INKBIRD Digital Meat Thermometer allows for accurate monitoring of various dishes at once. Each probe offers a measurement accuracy of 0.5°C (0.9°F) and can withstand temperatures up to 300°C (572°F).
- User-Friendly App Control: The accompanying app provides access to 23 USDA preset meat options, making it ideal for both beginners and seasoned chefs. Customize high/low-temperature alarms and set countdown timers to achieve perfect cooking results every time.
- Rechargeable Long-Lasting Battery: Featuring a built-in 2500mAh lithium battery, the thermometer operates continuously for up to 32 hours on a single 3.5-hour full charge via a Type-C cable, ensuring uninterrupted cooking sessions.
- Convenient Design Elements: The backlit LCD screen with adjustable brightness ensures clear visibility in any lighting condition. Its magnetic back and foldable stand provide flexible placement options, whether attaching it to an oven or positioning it on a countertop.
The INKBIRD IBT-26S WiFi Thermometer is perfect for grilling, smoking, baking, and more. Its high-precision probes and smart monitoring capabilities help prevent overcooking or undercooking, ensuring your meals are cooked to perfection. Whether you're a home cook or a professional chef, this meat thermometer for grilling enhances your culinary skills by providing accurate and real-time temperature data.
