INKBIRD IHC-200-WIFI Humidifier Dehumidifier Automatic Humidity Controller Humidistat Remote Data Monitor Smart Home Improvement
  • Dual-mode Operation: Automatically toggles between humidifying and dehumidifying modes for seamless environmental control
  • Wi-Fi Remote Control: Manage humidity settings remotely using the INKBIRD app, supporting only 2.4 GHz networks for enhanced stability
  • Alarms and Safety Measures: Alerts users if humidity levels exceed thresholds or if errors are detected, ensuring safety and preventing equipment damage
  • Humidity Calibration: Offers humidity calibration to ensure precision, critical for delicate environments like greenhouses or incubators.
  • Delay Protection Function: Protects devices from power surges and extends the lifespan of connected appliances
The INKBIRD IHC-200-WIFI Humidifier Dehumidifier Automatic Humidity Controller is an advanced humidity monitor designed for precise and remote control over indoor humidity levels. It seamlessly manages humidifiers, dehumidifiers, and fans through Wi-Fi connectivity, making it ideal for smart home environments. Whether used in residential spaces, greenhouses, reptile enclosures, or mushroom cultivation, this device ensures an optimal environment by switching between humidification and dehumidification modes automatically.
Key Features and Benefits:
  • Dual-mode Operation: Automatically toggles between humidifying and dehumidifying modes for seamless environmental control.
  • Wi-Fi Remote Control: Manage humidity settings remotely using the INKBIRD app, supporting only 2.4 GHz networks for enhanced stability.
  • Alarms and Safety Measures: Alerts users if humidity levels exceed thresholds or if errors are detected, ensuring safety and preventing equipment damage.
  • Delay Protection Function: Protects devices from power surges and extends the lifespan of connected appliances.
  • Humidity Range: 10-99% RH with ±3-5% RH accuracy.
  • Voltage: Supports devices with voltages from 100-265V.
  • Display: Digital readings with 0.1% RH accuracy.
  • Application Areas: Suitable for horticulture, animal enclosures, ventilated spaces, curing chambers, and other spaces that demand reliable humidity control.
The IHC-200-WIFI not only provides exceptional control but also eliminates the hassle of frequent manual checks, ensuring efficiency and peace of mind for users. By integrating a digital humidity controller with Wi-Fi access, the device becomes an essential part of any modern smart home setup.
