WIFI connectivity allows remote control via smartphone, so you can manage watering schedules even when away from home
Seasonal adjustment ensures optimal water usage based on changing weather, which helps reduce wastage and improve plant health
The Digital Sprinkler Timer supports rain skip functionality, halting watering during rain to conserve water and prevent overwatering
Four cyclic watering options make it easy to customize irrigation based on the specific needs of each zone
The built-in non-volatile memory retains settings, even in the event of power outages, ensuring continuity in watering schedules
Shop INKBIRD WIFI Water Timers For Sprinklers
The INKBIRD WIFI Smart Sprinkler Controller is a programmable irrigation system designed for precise, automated garden care. It manages up to six zones, making it suitable for various plant types, lawns, or flower beds. Equipped with an intuitive digital LCD screen, this controller allows seamless scheduling through its INKBIRD app and supports manual watering mode for special occasions when extra care is needed.
Features and Benefits
- WIFI connectivity allows remote control via smartphone, so you can manage watering schedules even when away from home.
- Seasonal adjustment ensures optimal water usage based on changing weather, which helps reduce wastage and improve plant health.
- The Digital Sprinkler Timer supports rain skip functionality, halting watering during rain to conserve water and prevent overwatering.
- Four cyclic watering options make it easy to customize irrigation based on the specific needs of each zone.
- The built-in non-volatile memory retains settings, even in the event of power outages, ensuring continuity in watering schedules.
With compatibility across various climates and its water-saving design, this WIFI Garden Watering Timer is ideal for home gardeners and larger estates. Additionally, its modern LCD display makes setting schedules straightforward and visually clear, while offering support for third-party integrations with weather updates.
Whether you automate your landscape with Water Timers for Sprinklers or use it as a Smart Sprinkler management tool, the INKBIRD controller provides precision, convenience, and flexibility to keep your garden thriving year-round.
