Letzgo AC Low Voltage Digital Dimmer
$152.95
Sleek and Modern Design: The Letzgo Digital Dimmer blends seamlessly with any décor, adding a touch of sophistication to your lighting setup
Easy Installation and Use: Simple to install, this AC low voltage dimmer is user-friendly, making it an ideal choice for both DIY enthusiasts and professionals
Digital Display: The clear and easy-to-read digital display ensures precise control over your lighting levels, allowing you to achieve the desired brightness with mini..
Energy Efficiency: The low voltage design ensures that your lighting system is energy-efficient, making the Letzgo Digital Dimmer an eco-friendly choice that can help ..
Versatile Lighting Control: Whether you want to create a cozy atmosphere for relaxation or brighten up a workspace for productivity, the Letzgo AC Low Voltage Digital ..
The Letzgo AC Low Voltage Digital Dimmer is the perfect solution for controlling your low voltage lighting needs with precision and ease. Featuring a sleek and modern design, this low voltage dimmer is both aesthetically pleasing and highly functional. The intuitive digital display allows you to effortlessly adjust the brightness of your lights, helping you create the perfect ambiance in any room.
Features of Letzgo Digital Dimmer:
- Sleek and Modern Design: The Letzgo Digital Dimmer blends seamlessly with any décor, adding a touch of sophistication to your lighting setup.
- Easy Installation and Use: Simple to install, this AC low voltage dimmer is user-friendly, making it an ideal choice for both DIY enthusiasts and professionals.
- Digital Display: The clear and easy-to-read digital display ensures precise control over your lighting levels, allowing you to achieve the desired brightness with minimal effort.
- Energy Efficiency: The low voltage design ensures that your lighting system is energy-efficient, making the Letzgo Digital Dimmer an eco-friendly choice that can help reduce your energy bills.
- Versatile Lighting Control: Whether you want to create a cozy atmosphere for relaxation or brighten up a workspace for productivity, the Letzgo AC Low Voltage Digital Dimmer provides the flexibility to meet your specific lighting needs.
Transform your home or workspace with the Letzgo AC Low Voltage Digital Dimmer. Its advanced features and user-friendly design make it the ideal tool for achieving optimal lighting control and energy efficiency.
Product Specs:
| Manufacturer Part #: | AC-LVDD-1210 |
| Current Capacity: | 10A |
| Operation: | 12VAC |
| Max Load: | 120W at 12V (No minimum load required) |
| Frequency: | 50Hz – 60Hz |
