Meross HomeKit WiFi Smart Water Leak Sensor Wireless Detector Water leakage Alarm Security Work with Alexa SmartThings
Instant Alerts & Alarm: Get real-time alerts on your smartphone when the sensor detects water leakage. A built-in alarm produces a sound of up to 60 dB to notify y..
Wireless Water Leak Detector: The device operates wirelessly, using a smart hub connection. Its battery can last up to 18 months, ensuring continuous monitoring
IP67 Waterproof: Engineered to withstand tough conditions, the sensor is waterproof and designed for use in humid environments
Automation & Integration: With the Meross app, you can automate responses like turning off connected appliances if leaks are detected, providing both security and ..
Shop Meross Water leakage Detector
The Meross HomeKit WiFi Smart Water Leak Sensor is a highly efficient solution for safeguarding your home against water damage. This compact device quickly detects leaks, sending instant notifications to your smartphone through the Meross app or Apple Home app. It integrates seamlessly with Apple HomeKit, Alexa, and SmartThings, offering hands-free control and automation for enhanced convenience.
Product Features:
- Instant Alerts & Alarm: Get real-time alerts on your smartphone when the sensor detects water leakage. A built-in alarm produces a sound of up to 60 dB to notify you immediately of any incident.
- Wireless Water Leak Detector: The device operates wirelessly, using a smart hub connection. Its battery can last up to 18 months, ensuring continuous monitoring.
- IP67 Waterproof: Engineered to withstand tough conditions, the sensor is waterproof and designed for use in humid environments.
- Automation & Integration: With the Meross app, you can automate responses like turning off connected appliances if leaks are detected, providing both security and peace of mind.
Usage & Benefits:
- Place the Smart Water Leak Sensor near appliances, pipes, basements, or bathrooms to detect potential leaks before they cause damage.
- The Wireless Water Leak Detector can help prevent costly repairs by notifying you early, whether you're home or away.
- The hub, capable of supporting multiple devices, makes it easy to expand your smart home setup with other Meross products like thermostats and window sensors.
