Optex Outdoor PIR Motion Sensor, Standard-Range Model
$119.95
The Optex Outdoor PIR Motion Sensor is a high-quality standard-range model that is perfect for adding an extra layer of security to your property. This motion sensor is designed with advanced technology that detects movement within its range, making it ideal for use in outdoor areas such as driveways, walkways, and gardens. With a detection range of up to 40 feet, this sensor is highly sensitive and can detect even the slightest movements. The Optex Outdoor PIR Motion Sensor is easy to install and comes with all the necessary hardware. It is weather-resistant and durable, making it suitable for use in any outdoor environment. This motion sensor is compatible with most security systems and is an excellent addition to any home or business security setup. With its reliable performance and advanced features, the Optex Outdoor PIR Motion Sensor is the perfect solution for your security needs.
| Detection Method | Passive Infrared |
| Detection Area | 40 x 50 feet (12 x 15 m) 120° wide |
| Coverage |
Multi-level area: 40 zones Pet alley area: 18 zones |
| Mounting |
Multi-level area: 8.3 feet (2.5 m) Pet alley area: 4 to 5 feet (1.2 to 1.5 m) |
| Detection Speed | 1 to 3.3 feet/second (0.3 to 1.0 m/sec.) |
| Sensitivity Adjustment | Selectable 3 positions (H, M, L) |
| LED Indicator | LED lights during detection |
| Alarm Period | 2 seconds ±1 sec. (delay timer) |
| Alarm Output | NC. NO. 28VDC 0.2A max. |
| Tamper Switch | Opens when cover removed. |
| Pulse Count | 2 (20 ±5 sec.) or TEST (1 pulse) |
| Day/Night Mode Adjustment | Approx. 10 to 100,000 lux |
| Warm-Up Period | Approx. 60 seconds |
| Power Input | 10.8 to 13.2V DC |
| Current Draw | 25mA max. |
| Installation Place | Wall (indoor/outdoor) |
| Operating Temperature | -20° to 50° C (-4° to 122° F) |
| Environmental Humidity | 95% max. |
| Weight | 6 ounces (170g) |
| IP Rating | IP54 |
| Accessory | Masking strips (LX-402 only), mounting screw, sponge |
