Philio Switch Module With Meter
PAN03 is a small, innovative and good performance smart In Wall
Switch. The built-in power meter can let you monitor the power
consumption of your electric appliances. PAN03 is also a well-designed
and remotely intelligent device. You can easily know the states of your
home appliances like lamps or fans. And no need to worry about if they
are not turned off. You can switch the lamp off or turn the oven off when
you are in office or even go on a vacation.
