Revolutionize Your Home with the Tuya Zigbee 3.0 Smart Light Switch Featuring 6M Radar Motion Detection – No Neutral Wire Needed!
HIGHLIGHT
NOT:When using No Neutral Wiring,No Need to connect capacitors
HIGHLIGHT
【 No need for voice control】Relying on physical radar sensing, no need for voice commands, simplifying operation, improving user experience, and making operation intuitive and convenient.
【TWO wiring methods】Support Neutral Wire system and No Neutral Wire system.Support single fire system,but you need a capacitor when you use No Neutral Wire ystem.
【APP Remote Control 】Download smart life /Tuya smart APP on your phone&Tablet to control the switch anywhere/anytime.
【 High cost-effectiveness and integrated functionality】With just one Tuya Tuya ZigBee radar switch, it can replace the traditional combination of switch and infrared sensor, simplifying the layout of smart homes.
【 Precise detection with 10G millimeter wave radar】Adopting 10G high-frequency radar technology, with a detection range of 6 meters and 100 ° wide-angle coverage, it can quickly perceive the presence or subtle movements of the human body, suitable for multiple scenarios such as bedrooms, corridors, warehouses, etc.
【 19th sensitivity adjustment】Through millimeter wave algorithm optimization, it supports 19 levels of sensitivity adjustment, adapts to different environments, reduces accidental touches, and provides a more accurate experience.
【 Intelligent energy-saving】Automatically adjust the switch status according to the environment and personnel activities, automatically turn off the power when no one is around, reduce energy waste, and lower electricity costs.
【 Security guarantee】Automatic night lighting to avoid searching for switches in the dark and reduce the risk of falls, especially suitable for the elderly and children.
【 Ultra long delay function】Supports up to 8 hours of delayed closing/opening, suitable for short-term stays and long-term usage needs, ensuring flexibility in both daily life and work.
【ZigBee Version】Tuya ZigBee Gateway/Hub is required.
【Supports three modes】Default on, default off, memory function: restores the state before power failure, no need to reset.
【Group control】One click control of multiple devices, convenient for setting "sleep mode" (turning off lights and sockets).
【Offline alarm】When the device malfunctions, the APP will push a reminder and support remote restart.
【Device sharing】Supports up to 5 family members to share devices and independently set operational permissions
SPECIFICATION
APP: Smart Life
Material: V0 flame retardant PC+ABS
Voltage: AC110~240V 50/60Hz
Radar sensing angle: 100 °
Radar sensing distance: 6m
Working temperature: 0 ℃~40 ℃
Power: 7-500W/per channel (single live wire), 0-700W/per channel (neutral live wire)
Wireless frequency: ZigBee 3.0
【Functional scenario based selling points】
1. Corridor/staircase safety lighting
Automatically turn on the lights at night to prevent elderly and children from falling and enhance home safety.
2. Intelligent linkage at the entrance
The light will turn on as soon as the door is opened, and the app will notify family members to come home in real time, keeping them updated on the latest developments at home.
3. Energy saving in warehouses/garages
Automatic power-off when unmanned, saving 37% energy compared to traditional solutions, suitable for scenarios such as warehouses and garages, and can operate stably even in high temperature environments.
matters needing attention:
1. Voice function not supported: relies on radar sensing and physical operation. Please choose the control method according to your actual needs.
2. It needs to be used in conjunction with a ZigBee gateway to ensure proper connection and stable operation of the device. Recommend using the "C Intelligent" series multi-mode gateway to ensure a more stable connection.
3. Power off operation before installation: When installing or maintaining, be sure to cut off the power first to avoid the risk of electric shock, and use a professional electrician.
4. Installation location suggestion: To achieve the best radar sensing effect, it is recommended to avoid aligning the installation location with direct sunlight, strong winds, or other equipment that may interfere with radar detection.
5. Delayed shutdown function: Supports a maximum of 8 hours of delayed shutdown or activation function. Please adjust the delay time according to actual needs. Long delays may affect energy efficiency.
6. Not suitable for large area coverage: The radar sensing range of this product is up to 6 meters, suitable for small to medium-sized spaces such as corridors, stairs, and entrances. It is not recommended for large rooms or outdoor environments.
