Sensative Strips Drip 800 Water Leak & Temperature Sensor, Retail Package
$40
Protect your home or business from water damage with Sensative Strips Drip 800 Water Leak & Temperature Sensor, Retail Package. This easy-to-install sensor detects water leaks and changes in temperature, alerting you via your smartphone or other connected device Ezlo.
The retail package includes one sensor, making it perfect for monitoring a single room or area. With its compact design and long battery life, Sensative Strips Drip 800 is the ideal solution for protecting your property and giving you peace of mind.
Manufacturer Part #: 11040321
EAN: 7350088520338
Frequency: 915 MHz
Z-Wave Version: 800 Series
Z-Wave Security: S2 and Secure Vault
Z-Wave Functionality: Smart Start
Features: Leak Detection Alarm
Ambient Light Reporting (0 to 64000 LUX)
Temperature Reporting and Alarm
Z-Wave Notifications: Binary Notification
Basic Reporting Types
Temperature Accuracy Ranges: ± 2 °C between -20 to 0°C (-4 to 32°F)
± 1 °C between 0 to 30°C (32 to 86°F)
± 2 °C between 30 to 60°C (86 to 140°F)
Range: Up to 390 ft (120 meters) line of sight
Up to 1640 ft (400 meters) across a Z-Wave network
Up to 2620 ft (800 meters) within a Z-Wave LR compatible network
Dimensions: Sensor: 195 H x 15 W x 3 D mm (7.68 H x 0.59 W x 0.11 D in)
Mounting: 193 x 14.7 x 2.7 mm (7.60 H x 0.58 W x 0.11 D in)
Operating Conditions: -20 to 60°C (-4 to 140°F)
Power Supply: Built-in LiMnO2 battery. Lasts up to 10 years.
Wake Up Intervals: 30mins to 24 hours (default 24H)
