Smart Zigbee 3.0 Controller Dimmable Ambiance LED Kit with 5M RGBCCT LED Light Strips Compatible Zigbee HUB Bridge,Echo Plus
【Zigbee HUB Required】The Zigbee LED Controller(ZC05M)Compatible with zigbee hub Bridge,Gateways Lightify Hub,Amazon Echo Plus and Tuya Smart Hub for Smart APP Control your LED lights from anywhere;
【Alexa Voice Control】No Zigbee gateway required,Zigbee 3.0 controller can directly work with:Amazon Echo Plus,Amazon Echo Plus (2nd Gen),Echo (4th Gen),Echo Studio,Echo Show (2.Gen) and other smart speakers with built-in zigbee 3.0 protocol.Voice control turn on/off lights,adjust the color and brightness.
【Smart APP Control】Create Ambiance Lighting for different scenes to meet your lighting needs throughout the day,Or create a schedule to save your time.If you don’t have a gateway,zigbee controller won’t work
【Dimmable RGB+CCT LED】You can get Pure White light instead of mixing RGB white light,Support set warm white/cool white(2700K-6000K)and offer more than 16 million colors for create your ideal mood Lighting.
【Easy to use】Plug and Play. comes with a UL approved adapter, a ZigBee Controller, 5m Not waterproof RGB CW WW Full Color LED Flexible lightstrip.perfect for spectacular and expressive color light design,apply to kitchen,cabinet,bars and so on.
Note:
ZigBee HUB Required
The Zigbee Strip Controller works with ZigBee Light Link Gateways/ like Lightify Hub,Homee,Smart Friends and Alexa Echo Plus,But this zigbee strip controller don't compatible with Wi-Fi Device of the 2nd Gen Echo dot and the 3nd Gen Echo,They must be Link to the Zigbee Hub (ZigBee Bridge and Lightify Hub)
Product Parameters:
Product Name:ZIGBEE3.0 Wireless LED Controller Kit
Model NO:ZC05M
Input Voltage:DC12V-24V
Output Current:5A Max
Total Power:120W Max
Package include:
1 x Zigbee 3.0 RGBCCT Controller
1 x 5m RGBCCT LED Strip Light
1 x UL Listed 12V Power Adapte
