Smart Zigbee 3.0 Led Downlight RGB+CW+WW 4 Inch round Ceiling Light Work with Hub Bridge Hub Echo plus Alexa Voice Control
【Zigbee HUB Required】The Smart Retrofit Recessed Downlight Compatible with ZigBee Hub Bridge,Gateways Lightify Hub,Amazon Echo Plus and Tuya Smart Hub;If you don't have these gateway,it will not work
【Smart APP Controlled】Download the APP according to the gateway you will connect to and control your RGBWW LED lights anytime,anywhere.Create personalized scene modes to meet all day lighting needs
【Alexa Voice Control】✅No gateway required,the zigbee 3.0 controller can be directly work with:Echo Plus,Echo Studio,Echo Show(2.Gen) Use simple voice commands to control LED Recessed Lighting turn on/off,dimming or change colors(Don't work with Echo dot)
【Dimmable RGB CW WW White&Color Ambiance Recessed Downlight】you can get pure white light from warm white 3000K to cold white 6000K.and offer 16 million color changes,1%-100% brightness is adjustable.Zigbee controller remembers the last color setting after switching off
【Easy Installation】Aluminum alloy lamp body,better heat dissipation and longer life(hole size:4 inch; Ideal for 95mm-100mm recessed housing cans)Ideal for recessed lighting retrofits or new construction installation
【Group Control&Timer】you can control all Smart Downlights on same time by Set a group on the app;Preset Smart LED Can Lights Auto turn on/off.The unique wake-up mode will let the light wake you up gently and gradually dim light to help you to sleep
Connect with Gateway :
1. Connect the LED product to the power socket.
2. Start the device searching on the ZigBee Light Link Gateway which may take some time.(If the Gateway does not find the device, pls reset the lights)
3. You can assign it to the different rooms/zones/groups after the Gateway found your device.
4. Now you can use the device.
Notes: The Zigbee lights works with ZigBee Light Link Gateways / such as Lightify Hub,Homee,Smart Friends and Ama*zon Echo Plus and the 3rd generation Echo must be connected to the Zigbee Hub (Lightify Hub )
If the gateway cannot find the device and reset can't work,please try to restart the router and zigbee gateway.
Model NO:GD-DLZ12
Input:AC100-240V 50-60 HZ
Control options: Zigbee Hub APP control/ Voice Control by Alexa
Color: RGB+Warm white+Cold white
Zigbee 3.0 Smart RGBCCT Downlight
Hole Size: 95 / 100(mm)
