Smart Zigbee Human Presence Sensor 24G Mmwave Radar +Pir,Luminance Detection Use Battery Support Zigbee2Mqtt Home Assistant
*Attention:
The Sensor are only compatible with home assistants or Z2MQTT. Please use it on a home assistants or Zigbee 2mqtt.
If you have any questions during use, please contact the seller first and we will provide assistance,Thank you!
Upgraded version Mmwave 24G Radar, For more accurate detection.
【How does it work
This is a low-power version that frist detects humans through infrared detection,Can detection movement detection,static detection(breathing,minor movement)Implement more automation scenarios.
Wireless Protocol: Zigbee 3.0
Stationary Detection Range:0~600cm
Moving Detection Range:0~1000cm
Battery Powered ,More easy to use(packaging not including batteries)
Packaging contains:
Human Presence Sensor X 1
User Manual X 1
Adhesive patch X 1
