Smart Zigbee RGB FCOB LED Strip Lights 5M 10M DC24V Soft Bending Tape Light Set Bedroom Decoration Atmosphere Lighting Diodes
【ZigBee Hub Required】The ZigBee 3.0 LED controller of this RGB ZigBee LED strip light COB needs ZigBee 3.0 hub bridge to work,which compatible with ZigBee 3.0 Hub such..
【Alexa Voice Control ZigBee RGB COB LED strip light】No gateway required:Zigbee 3.0 LED Controller can directly work with:Echo Plus (2nd Gen),Echo (4th Gen),Echo Studio..
【Smart Hub APP Control】Control the smart COB LED strip kit at home through the Hub APP on your mobile phone anytime, anywhere. Preset time switch, set RGB color mixing..
【Flexible High Density RGB FCOB LED Strip】This RGB COB LED strip tunable kit has a working voltage of 24V, which is environmentally friendly and safe. The entire roll ..
【Widely used smart COB LED strip】This RGB COB LED strip light 32.8ft is soft and easy to bend, suitable for DIY in various scenes, and supports cutting. You can choose..
Intelligent ZIGBEE COB RGB Led Stirp Lights 24V String Night light Decoration Bedroom Diode Tape Warm White Lighting Atmosphere Lamp
【ZigBee Hub Required】The ZigBee 3.0 LED controller of this RGB ZigBee LED strip light COB needs ZigBee 3.0 hub bridge to work,which compatible with ZigBee 3.0 Hub such as Tuya Smart Hub etc,If you don't have a ZigBee Hub,this ZigBee COB LED strip light 24V will not work
【Alexa Voice Control ZigBee RGB COB LED strip light】No gateway required:Zigbee 3.0 LED Controller can directly work with:Echo Plus (2nd Gen),Echo (4th Gen),Echo Studio,Echo Show (2.Gen) and other smart speakers which built-in zigbee3.0 protocol. Simply voice commands to adjust brightness,change colors or turn on/off ZigBee led strip
【Smart Hub APP Control】Control the smart COB LED strip kit at home through the Hub APP on your mobile phone anytime, anywhere. Preset time switch, set RGB color mixing, cob led strip dimmable 1%~100%
【Flexible High Density RGB FCOB LED Strip】This RGB COB LED strip tunable kit has a working voltage of 24V, which is environmentally friendly and safe. The entire roll length is 32.8ft/10m, with 5050SMD RGB 6720 lamp beads, which can create high brightness, soft, continuous 16milion RGB mixed color light with no dark spots
【Widely used smart COB LED strip】This RGB COB LED strip light 32.8ft is soft and easy to bend, suitable for DIY in various scenes, and supports cutting. You can choose from bright and rich R.G.B mixed colors as you like, adjust the brightness according to your needs, and easily customize the ambient lighting mode you want
Details:
Color RGB (Red, Green, Blue)
Indoor/Outdoor Usage:Indoor
Special Feature:Dimmable
Light Source Type:LED
Power Source Corded Electric
Light Color:Multicolor
Material:Plastic
Controller Type:Am*a*zon Alexa, App Control, Voice Control
Number of Light Sources:150
Voltage:24 Volts
Wattage:128 watts
Item Weight:500 Grams
Number of Items:1
Control Method:App, Voice
Seasons Autumn, Spring, Summer, Winter
Form Factor:Strip Light
Package Included:
RGB COB LED Strip : 1 Roll 5m RGB COB Light Strip ( Excluding power supply,led controller and other accessories )
5m COB LED Set : 1 Roll 5m RGB COB Light Strip + Zigbee Controller + Remote control (without battery)
+ Power supply (according to your choice)
10m COB LED Set : 1 Roll 10m RGB COB Light Strip + Zigbee Controller + Remote control (without battery)
