SONOFF SNZB-02D Zigbee LCD Smart Temperature Humidity Sensor APP Real-time Monitoring Work with ZB Bridge-P/ ZB Dongle/ NS Panel
  • High Accuracy: Temperature accuracy of ±0.2°C and humidity within ±2%RH
  • Real-Time Monitoring: Receive alerts and view historical data through the app
  • Multiple Mounting Options: Tabletop, magnetic back, or adhesive for flexibility
  • Wide Coverage: Signal reaches up to 120m (400ft) under optimal conditions
  • Smart Automation: Use temperature and humidity as triggers for other devices
The SONOFF SNZB-02D Zigbee LCD Smart Temperature Humidity Sensor is a cutting-edge device designed to provide real-time monitoring of environmental conditions. With its 2.5-inch LCD display, the sensor offers precise data on temperature and humidity, allowing users to stay informed and adjust conditions for optimal comfort. Whether you're managing home spaces, monitoring greenhouses, or preserving collectibles, this smart sensor delivers accurate readings and integrates seamlessly with Zigbee 3.0 gateways, such as the SONOFF Zigbee Bridge-P and NS Panel Pro.
The SONOFF SNZB-02D Zigbee LCD Smart Temperature Humidity Sensor delivers unparalleled comfort through accurate, real-time measurements. This Zigbee Temp Humidity Sensor utilizes Swiss-made sensors for high precision—boasting temperature accuracy within ±0.2°C and humidity accuracy of ±2%RH. With a quick refresh rate every 5 seconds, it ensures you always have the most up-to-date data displayed on its large, bold LCD screen.
This sensor connects effortlessly with Zigbee hubs such as the SONOFF ZBDongle-P and the NSPanel Pro. The accompanying app provides real-time monitoring and alerts whenever temperature or humidity levels exceed preset ranges. The device can act as a trigger for other smart appliances, like turning on a humidifier when humidity drops below a certain point, offering smart automation for enhanced comfort.
Designed for versatility, the Zigbee Humidity Sensor can be mounted using a magnetic back, tabletop stand, or adhesive pads. Its wide 120m (400ft) signal range makes it ideal for various spaces, from living rooms to greenhouses, cellars, or even incubators. You can also ask Alexa or Google Home to provide current readings, ensuring complete hands-free operation.
With long battery life (up to two years) and cloud data storage, users can monitor trends through visual graphs over days, months, or even half-year intervals. This Zigbee LCD Smart Temperature Humidity Sensor is more than just a tracker—it enhances home automation, providing peace of mind for homeowners and plant enthusiasts alike.
  • High Accuracy: Temperature accuracy of ±0.2°C and humidity within ±2%RH.
  • Real-Time Monitoring: Receive alerts and view historical data through the app.
  • Multiple Mounting Options: Tabletop, magnetic back, or adhesive for flexibility.
  • Wide Coverage: Signal reaches up to 120m (400ft) under optimal conditions.
  • Smart Automation: Use temperature and humidity as triggers for other devices.
  • Hands-Free Control: Works with Alexa and Google Home.
This sensor is an excellent addition to any smart home setup, ensuring precise environmental control for optimal living conditions​.
