SONOFF SNZB-02P Zigbee Temperature Humidity Sensor 1-10PCS Smart Home Works with SONOFF iHost, ZB Bridge-P, ZBDongle-E
  • Zigbee 3.0 Protocol for stable and fast communication
  • Swiss-made sensor for high-precision temperature (±0.2°C) and humidity (±2%RH)
  • Real-time updates every 5 seconds, ensuring you get the most current data
  • Cloud storage of historical data for easy access and analysis of trends
  • Multiple mounting options, including adhesive, screw, and metal plate for flexibility
Sonoff SNZB-02P Zigbee Temperature and Humidity Sensor is an essential addition to any smart home. With the Zigbee 3.0 protocol, this device provides accurate and real-time measurements of both temperature and humidity, ensuring your living space remains comfortable and safe. The Zigbee Temperature Sensor offers a high level of precision, with temperature accuracy up to ±0.2°C and humidity accuracy within ±2%RH. Its seamless integration with platforms like Sonoff iHost, NSPanel Pro, and ZB Bridge Pro allows you to monitor and control your environment effortlessly through the eWeLink app or voice assistants like Alexa and Google Home.
This ZigBee Temperature and Humidity Sensor is designed for easy installation, offering multiple mounting options including adhesive, metal plate, or screw mounting. Whether you place it in a living room, greenhouse, reptile terrarium, or baby room, you can always stay updated with real-time environmental data. The sensor’s long battery life and low power consumption make it highly reliable for continuous monitoring. The Sonoff Temperature and Humidity Sensor also allows you to set up alerts, notifying you when temperature or humidity levels exceed your desired thresholds, so you can take action promptly.
  • Zigbee 3.0 Protocol for stable and fast communication.
  • Swiss-made sensor for high-precision temperature (±0.2°C) and humidity (±2%RH).
  • Real-time updates every 5 seconds, ensuring you get the most current data.
  • Cloud storage of historical data for easy access and analysis of trends.
  • Multiple mounting options, including adhesive, screw, and metal plate for flexibility.
Ideal for use in homes, greenhouses, reptile terrariums, or anywhere you need to monitor environmental conditions, the Zigbee Temperature Sensor ensures your space is always at the ideal temperature and humidity levels. You can access real-time data through the eWeLink app and set personalized alerts for convenience.
  • Enhanced comfort through precise environmental control.
  • Data storage and trend tracking to optimize living conditions.
  • Easy integration with existing smart home devices, including Alexa, Google Home, and more.
  • Simple setup with long-lasting battery life for uninterrupted service.
