SONOFF SNZB-05P Zigbee 3.0 Water Leak Sensor Leaking and Dripping Detection Real-time Alerts Support Home Assistant Google Alexa
$23.76
Color: SNZB-05P
IP67 Waterproof and Dustproof: Ensures reliable performance even in humid and dusty environments, providing short-term immersion protection
Gold-Plated Probes: Equipped with corrosion-resistant gold-plated probes, enhancing durability and longevity
Extended Detection Cable: Includes a 2-meter detection cable to monitor larger areas, making it ideal for basements, kitchens, or attics
Long Battery Life: Powered by a CR2477 battery, the sensor offers an extended battery life of over five years, reducing the need for frequent replacements
Smart Home Integration: Compatible with platforms like Home Assistant and Google Alexa, allowing for seamless integration into your existing smart home setup.
Shop SONOFF SNZB-05P Zigbee 3.0 Leak Detector Seamless Smart Home Integration
The SONOFF SNZB-05P is an advanced Zigbee 3.0 leak detector that provides real-time alerts for water leaks and drips, safeguarding your home from potential water damage. This compact and efficient drip and leak detection sensor integrates seamlessly with your smart home ecosystem, offering peace of mind through timely notifications.
- IP67 Waterproof and Dustproof: Ensures reliable performance even in humid and dusty environments, providing short-term immersion protection.
- Gold-Plated Probes: Equipped with corrosion-resistant gold-plated probes, enhancing durability and longevity.
- Extended Detection Cable: Includes a 2-meter detection cable to monitor larger areas, making it ideal for basements, kitchens, or attics
- Long Battery Life: Powered by a CR2477 battery, the sensor offers an extended battery life of over five years, reducing the need for frequent replacements.
- Smart Home Integration: Compatible with platforms like Home Assistant and Google Alexa, allowing for seamless integration into your existing smart home setup.
Place the SONOFF SNZB-05P Zigbee water leak sensor in areas prone to leaks, such as under sinks, near water heaters, or in basements. Upon detecting water, the sensor sends immediate alerts to your connected devices, enabling you to take swift action and prevent potential water damage. Its robust design and extended detection capabilities make it a reliable choice for comprehensive home water leak monitoring
