Speaker Wire, 14AWG, 2C, Direct Burial, OFC Shielded, 500 Ft.
Regular price $252.95
Regular price $252.95 Sale price
Introducing our premium quality speaker wire, designed to deliver exceptional performance and reliability. This 14AWG, 2C wire has been specifically engineered for direct burial, ensuring that it can withstand the toughest outdoor environments. The OFC shielded construction offers superior protection against interference and noise, ensuring that you get a crystal-clear audio signal every time. With a massive 500 ft. length, this wire is perfect for long-distance installations and larger projects. So whether you're setting up a home theater system or installing outdoor speakers, our speaker wire is the perfect choice for the job. Buy now and experience the difference in sound quality!
Manufacturer Part # 14/2SHDB-500
Marking STRUCTURED CABLE PRODUCTS – – – P/N 14/2SH-DB – – – 2 COND 14 AWG STRANDED SHIELDED PE JKT CMX OUTDOOR / DIRECT BURIAL — CE EU RoHS EC ZONE/DEVICE A B C D E 0 1 3 4 5 6 7 8 9 XXXXFT
Regulatory UL 444, UL 13, NEC Article 760, NEC Article 725 EU RoHS 2011/65/EU Compliant
Application Speaker Cable
Construction Characteristics Conductor Material: Stranded Bare Copper
Size: 14AWG X 2C (2.11mm²)
Construction: 105/0.16mm (0.0063 inch) ±0.004mm
Insulation Material: PVC
Min. Thickness: 0.33mm (0.0130 inch)
Avg. Thickness: 0.36mm (0.0142 inch)
Diameter: 2.60mm (0.1024") ±0.05mm
Colors: Black and Red
Shield Core Wrap: PE Tape
Drain Wire: 7/0.20mm (0.0008 inch) ±0.004mm
Shield: AL Foil
Filler: Waterproof
Jacket Material: LLDPE
Min. Thickness: 0.60mm (0.0236 inch)
Avg. Thickness: 0.54mm (0.0213 inch)
Diameter: 7.20mm (0.2835 inch) ±0.10mm
Color: Black
Electrical & Physical Characteristics Rating: 75°C 300V
Conductor Resistance: Max 9.2ohm/km at 20°C
Insulation Resistance: Min 50M ohm·km at 20°C
Dielectric Strength: Min AC1.5KV
AC Leakage Current Through Overall Jacket: AC 1500V
Twists Per Foot: 2.5
Cold Bend Test: -20°C 4 hours; No Cracking
Insulation Unaged:
Tensile Strength: 13.8Mpa
Elongation: 150 percent
Insulation Aged:
Tensile Strength: 11.7Mpa (100°C 168h)
Elongation: 80 percent (100°C 168h)
Jacket Unaged:
Tensile Strength: 10.8Mpa
Elongation: 300 percent
Jacket Aged:
Tensile Strength: 9.2Mpa (100°C 168h)
Elongation: 150 percent (100°C 168h)
