Speaker Wire, 16AWG, 4C, Direct Burial, 1,000 Ft.
Regular price $781.95
Regular price $781.95 Sale price
Introducing our high-quality Speaker Wire, designed with 16AWG thickness and 4 conductors for superior conductivity. This wire is perfect for outdoor use, featuring a Direct Burial design that withstands harsh weather conditions and exposure to moisture. With a length of 1,000 feet, this Speaker Wire offers plenty of coverage for your audio needs. Whether you're setting up a sound system for a backyard party or installing speakers around the perimeter of your property, our Speaker Wire delivers excellent sound quality and durability. Don't settle for subpar wiring - choose our Speaker Wire for reliable and long-lasting performance.
Manufacturer Part # 16/4DB
Marking STRUCTURED CABLE PRODUCTS – – – P/N 16/4-DB – – – 4 COND 16 AWG STRANDED PE JKT CMX OUTDOOR / DIRECT BURIAL — CE EU RoHS EC ZONE/DEVICE A B C D E 0 1 2 3 4 5 6 7 8 9 XXXXFT
Regulatory UL 444, NEC Article 760, NEC Article 725
Application Speaker Cable for Outdoor
Construction Characteristics Core Wrap: PE Tape
Filler: Waterproof
Conductor Material: Stranded Bare Copper
Size: 16AWG X 4C
Construction: 65/0.16mm (0.0063 inch) ±0.004mm
Insulation Material: PVC
Min. Thickness: 0.27mm (0.0106 inch)
Avg. Thickness: 0.31mm (0.0122 inch)
Diameter: 2.10mm (0.0827") ±0.05mm
Colors: Black, Red, White, Green
Jacket Material: LLDPE
Min. Thickness: 0.54mm
Avg. Thickness: 0.60mm (0.0339 inch)
Diameter: 6.80mm ±0.10mm
Rip Cord: Nylon
Color: Black
Electrical & Physical Characteristics Rating: 75°C 300V
Conductor Resistance: Max 15.5ohm/km at 20°C
Insulation Resistance: Min 50M ohm·km at 20°C
Dielectric Strength: Min AC1.5KV
AC Leakage Current Through Overall Jacket: AC 1500V
Cold Bend Test: -20°C 4 hours; No Cracking
Insulation Unaged:
Tensile Strength: 13.8Mpa
Elongation: 150 percent
Insulation Aged:
Tensile Strength: 11.7Mpa (100°C 168h)
Elongation: 80 percent (100°C 168h)
Jacket Unaged:
Tensile Strength: 10.8Mpa
Elongation: 300 percent
Jacket Aged:
Tensile Strength: 9.2Mpa (100°C 168h)
Elongation: 150 percent (100°C 168h)
