Speaker Wire 16AWG 4C, Direct Burial, Oxygen Free, 500 Ft.
Regular price $359.95
Regular price $359.95 Sale price
Introducing our Speaker Wire 16AWG 4C, Direct Burial, Oxygen Free, designed with high-quality materials to provide optimal sound transmission for your audio setup. This product features 16AWG wiring and four conductors, ensuring a strong and stable connection between your speakers and amplifier Speaker Wire 16AWG 4C, Direct Burial, Oxygen Free.
Speaker Wire 16AWG 4C, Direct Burial, Oxygen Free, The Direct Burial feature allows for easy installation outdoors and in harsh weather conditions, with the added benefit of being oxygen-free for superior sound quality. With an impressive length of 500 feet, you'll have plenty of wire to work with for even the most complex audio setups. Upgrade your audio experience with our Speaker Wire today. The specification of Speaker Wire 16AWG 4C, Direct Burial, Oxygen Free is below.
Manufacturer Part # 16/4OFC-HD-WT
Marking STRUCTURED CABLE PRODUCTS – – – P/N 16/4OFC-HD – – – 4C 16 AWG 65 STRAND OXYGEN FREE COPPER E198137 (UL) CL3R OR CMR C(UL)US FT4 75C DIRECT BURIAL – SUN RES PVC (ROHS) CE ZONE/DEVICE A B C D E 0 1 2 3 4 5 6 7 8 9 XXXXM
Regulatory UL 444, UL 13, NEC Article 760, NEC Article 725, Type (UL) CMR/CL3R or c(UL) FT4, EU RoHS 2011/65/EU Compliant
Application Speaker Cable
Construction Characteristics Conductor Material: Stranded Bare Copper
Size: 16AWG X 4C (1.31mm2)
Construction: 65/0.16mm (0.0063 inch) ±0.004mm
Insulation Material: PVC
Min. Thickness: 0.27mm (0.0106 inch)
Avg. Thickness: 0.31mm (0.0122 inch)
Diameter: 2.10mm (0.0827") ±0.05mm
Colors: Black, Red, White, Green
Jacket Material: PVC
Min. Thickness: 0.95mm (0.0374 inch)
Avg. Thickness: 0.86mm (0.0339 inch)
Diameter: 7.00mm (0.2756 inch) ±0.10mm
Rip Cord: Nylon
Color: White
Electrical & Physical Characteristics Rating: 75°C 300V
Conductor Resistance: Max 15.5ohm/km at 20°C
Insulation Resistance: Min 50M ohm·km at 20°C
Dielectric Strength: Min AC1.5KV
AC Leakage Current Through Overall Jacket: AC 1500V
Twists Per Foot: 2.5
Cold Bend Test: -20°C 4 hours; No Cracking
Insulation Unaged:
Tensile Strength: 13.8Mpa
Elongation: 150 percent
Insulation Aged:
Tensile Strength: 11.7Mpa (100°C 168h)
Elongation: 80 percent (100°C 168h)
Jacket Unaged:
Jacket Aged:
