Friend, welcome to our store, If you have any question, please contact me!
Products Description
SZMYQ Tuya ZigBee Smart IR Remote Control Universal Infrared Remote Controller for Smart Home Smart Life works with Alexa Google Home
ZigBee Smart IR Remote Controller 1.Infrared Angle with 360 Degree 2.Infrared Frequency:38-56K Hz, Infrared range ≤10M 3.Remotely Control Air Conditional,TV,MideaBox,Set-Top Box,I-Switch 4.Wireless Type:ZigBee 2.4GHz,Protocol:IEEE 802.15.4 5.Power by DC5V/1A 6.Works with Amazon Alexa Echo, Google Home
Advantage of products
SZMYQ Smart Home Infrared Blaster, Smart Remote Controller, Infrared Universal Remote Controller TV Air Conditioning Smart Home Controller Remote Timing for Tuya for Zigbee
1.Tuya ZigBee Wired Gateway Required:This Tuya smart ZigBee IR remote is designed with Tuya ZigBee wired gateway required for APP configuration and smart controls in Smart Life APP.(Note:Only a wired hub(Wired Multi-mode Gateways are also compatible! ) is compatible with the ZigBee IR remote,the wireless hub is not supported for APP configuration.)
2.All-in One Control by Smart Phones:All-in-one IR remote control devotes to activating house infrared appliances as Air conditioners, TVs, fans, DVDs, STBs, TV BOXes etc with one single MOES SMART IR (Only support Ir (38KHZ ) ,RF not included),adding all compatible devices into the remote for wireless remote control by smart phones anywhere you like;Control your appliances in advance when you are away from home.
3.Hands-free Voice Control:Alexa,set A/C to 77 degrees Fahrenheit. A voice command can activate MOES SMART IR controller to remotely control most Infrared Control Devices. Such as A/C, FAN ,TV, DVD, STB, TV BOX etc.(Furthermore compatible brands or devices ,please check attached list or Smart Life APP.)
4.Customized DIY Copy Function:If you can not find IR device brand in "smarlife"App,Programable DIY learning function may help to copy same function from original remote.Most IR remote control Devices will be applicable such as fireplaces, heater, ceiling fans,please confirm you have a traditional remote of the infrared devices for DIY learning by the ZigBee IR remote.
Details Images
Tuya ZigBee Smart IR Remote Control Universal Infrared Remote Controller for Smart Home for AC TV DVD works with Alexa Google Home Wired ZigBee Hub Required
Tuya APP Control
Remote Control your home appliances by using "Tuya Smart" App in your smart phone anywhere anytime. For example: Switch on home A/C in advance, enjoying the comfortable temperature once you get home.
Voice Control
By connecting Intelligent speaker, such as Amazon Alexa, Google Home, you are able to control your home appliances by voice. For example: Alexa, turn on TV; OK Google
Must Work with Wired Gateway
This Smart IR Remote requires Tuya zigbee Wired Hub to work together.
Timer and Automatic Trigger
According to your living habits, set time switches for your home appliances, such as turning on/off the air conditioner at regular intervals.
Third-Party Control
Works with Amazon Alexa, Google Assistant, Siri(iOS 12.0 or later), Tmall Genie, Tecent Xiaowei, DingDong, Rokid, DuerOS, etc.
Scenario and Automation in App
A scenario consists of 1 or more actions. By creating an "Scenario", you may control multiple devices with one tap; By adding an "Automation" and interworking with other smart home devices, Wi-Fi remote control is able to execute actions automatically according to conditions, such as device status, weather and time.
Product Name
Tuya smart zigbee TV AC remote control Universal IR Controller
Infrared Angle
360 degree
Infrared Frequency
Control Device
