Transform Your Home with the Tuya Zigbee Light Sensor - Smart Luminance Detector Compatible with Alexa and Google Home
HIGHLIGHT
Note:
This product is a Tuya Zigbee version of the luminancesensor. Please ensure that you have a Tuya Zigbee gateway before use. Because all Tuya Zigbee products must be used with Tuya Zigbee gateways.
This product can monitor light intensity in real-time, so you can directly use it as a brightness detector, t hrough the "Smart Life" app, you can view the current luminance around your device in real-time
Of course, using it as a DIY tool for smart homes would be the most suitable.
For example:
You can link it with your Tuya smart light bulb. If the light intensity is less than 100Lux, then the light bulb will turn on; If the light is above 500Lux, then the bulb will turn off.
You can link it with your Tuya curtain switch. If the light is less than 50Lux, then open the curtains; If the light exceeds 800Lux, then close the curtains.
You can use it in conjunction with any Tuya product to create your own DIY smart home, unleash your imagination and make your life more enjoyable.
Product parameters
Name:Tuya Light intensity sensor Zigbee Version
Wireless:Zigbee 3.0
Battery:DC3V lro3*2(not include)
Detection range:0~1000Lux
Working temperature:-10℃~+50℃
Working humidity:10%~95%RH
