Tuya Smart Zigbee Thermometer Home Indoor and Temperature Humidity Sensor with LCD Display APP Voice Control
Description
• Voice Control :Control the thermometer with your voice using Alexa or Google Home.
• LCD Display:The thermometer has an LCD display that shows the temperature and humidity levels.
• ZigBee Communication :The thermometer uses ZigBee communication to connect to your home network and send data to your phone.
• Ready-to-Go :The thermometer is ready to use out of the box, no assembly required.
Specifications
Communication modeZigBee
Operating temperature:-10 degrees Celsius to 55 degrees Celsius
Supply voltage:DC3V
Installation:3M glue
Humidity accuracy:+3%RH
Note:
1. 2*AAA batteries are not included in the pakcage because it will cause a trouble to shipment. Thanks for your understanding.
2. it needs a Tuya Zigbee gateway as a bridge to connect it to app
3. Please rotate the battery cover to the left to open it
Main Features
- Monitoring temperature and humudity changes for your home and send datas to your smartphone. Hub required.
- Radio transmission circuit and coding technology to solve signal interference blocking problem.
- Various temperature modes can be adjusted for different scenes.
- Ultra low power consumption and long battery life.
- With low voltage monitoring prompt function
Hands -Free Voice Control Supported ,It can control Alexa / Google Home voice assitant
It can accurately sense indoor temperature and humidity in real time, and has a clear digital LCD display.
Automation works well with other intelligent devices, such as electric heaters and humidifiers used in the whole house, and even the expiration date can be selected to achieve more flexible control
Extremely mini size featured,together with two placement methods as table place and wall-mounting mode for simple installation and usage.
