Tuya Zigbee Homekit Fingerbot Switch Button Push Touch Arms Fingerbot Wireless Thumb Remote Control Switch Works Alexa Google
Note: For HomeKit versions of finger robots, you need to add a ZigBee HomeKit gateway to the Home, and then go to the HomeKit in the Tuya APP to add a finger robot.
This device cannot be directly connected to the APP via Bluetooth or WiFi. It needs to work with Tuya Zigbee gateway/Multi -mode gateway.
Tool cannot be used alone. It need to be used with zigbee fingerbot plus!
Notice:
1.The zigbee fingerbot plus must be used with tuya zigbee gateway/Multi -mode gateway.
2.Work with Home Assistant Zigbee2MQTT and ZHA.(Z2M:1 gang switch. open/close switch) 3.Tool cannot be used alone. It need to be used with zigbee fingerbot plus.
Feature:
【New upgrade ZigBee version】:Tuya HomeKit ZigBee Gateway/Hub is required
【APP remote control 】:The smart fingerbot plus can be controlled by mobile phone connect zigbee gateway.
【Voice Control 】:The smart switch button pusher can be controlled through a voice device at home.
【Timed start】:You can set the time in the APP and start the fingerbot button at a regular time.
【Convenient installation】:Stick 3M glue on the bottom surface of the finger robot, paste it in the required position, open the mobile phone APP for configuration and use.
Specification:
Product Name: Zigbee Fingerbot Plus
Dimensions: 34.5*34.5*34.5mm
Weight: 38g
Battery: 1 * CR2 not battery included
Torque: 2.0 kgf.cm
Maximum arm movement: 12mm
Wireless Protocol: Zigbee 3.0
Working Temperature: -10℃-45℃
Zigbee Hub: ZigBee HomeKit gateway
Package Included:
1*Zigbee Fingerbot Plus
1*Tool(optional)
