Tuya Zigbee Water Leak Detector Flood Sensor Water Leakage Detector Smart Water Sensor Overflow Alarm Work with Zigbee Gateway
$8.26
Color: 1Pc
Attention please:
This is the Zigbee version and requires a Tuya gateway for connection!!!
Why buy?
The Tuya ZigBee Water Sensor is a smart home security device designed to detect water leaks and flooding in real time. It connects seamlessly with your smart home system via ZigBee protocol, sending instant alerts to your smartphone through the Tuya Smart App. Ideal for placing under sinks, near water heaters, or in basements, this sensor helps prevent costly water damage by notifying you the moment a leak is detected.
1. Real-Time Alerts: Receive instant notifications on your smartphone via the Tuya Smart App when water is detected.
2.ZigBee Connectivity: Works with Tuya ZigBee hubs for reliable, low-power smart home integration.
3.Smart Home Integration: Compatible with Amazon Alexa, Google Assistant for automated responses.
4. Easy Installation: Compact, wireless design with adhesive backing for quick placement in high-risk areas.
5.Remote Monitoring: Check the status of your home anytime, anywhere via the Tuya Smart App.
6.Automation Ready: Pair with smart valves or plugs to automatically shut off water in case of a leak.
Q&A
1.How to connect products?
This product connection requires Tuya zigbee gateway, the gateway is powered on, the product on the battery, the product should be as close as possible to the Zigbee smart gateway, and then long press the product reset button for 6 seconds until the indicator light flashes quickly, open the smart life or Tuya APP, click on the upper right corner of the “+” sign, click on the add device, and wait for the search to be added!
Specification
Battery:AAA Battery(Not included)
Standby Time:8 months
Operating Temperature:-10℃-55℃
Working Humidity:10%-90%RH(Non-condensing)
Wireless Standard:Zigbee3.0
Housing Material:ABS
APP Control:Smart Life /Tuya APP
Dimension:69*23*19mm
Wire Length:1m
Package Included:
water sensor*1
